Old 03-25-2014, 11:24 PM
Gofastoldguy's Avatar
Cobra Make, Engine: Factory Five Roadster
Default Question re: Oil capacity
What is the proper oil capacity for a 302 with a dual sump, including filter. I used 5 quarts and the dipstick shows a quart over. Is the dipstick wrong or am I the "dipstick" ? (Don't answer that Mike!)
Old 03-25-2014, 11:48 PM
Rick Parker's Avatar
5 Qt incl Full size FL1 filter.
Old 03-26-2014, 06:48 AM
Dwight's Avatar
Smile
add five qt and crank the motor let it run a minute or so. Shut it down and wait ten mintues. Re-mark the dipstick.
I've seen dipsticks off by 1 3/4 qts on FEs. To much oil.
Dwight
Old 03-26-2014, 11:53 AM
Oops.
_____________________
Old 03-26-2014, 07:29 PM
mikiec's Avatar
We talked about this already. Drain the oil out. Drive for a week, that will use up any remaining oil in the engine. Add one quart at a time. When you have dumped 5qts in your done. As stated, then mark the stick.
Send the 200.00 to Bruce.
Old 03-27-2014, 10:15 AM
CHANMADD's Avatar
I like to mark the dipstick when the motor is upside down on an engine stand........mark just below the crank throw ............when its running there will be a quart or more in the top of the engine.....
Old 03-27-2014, 10:35 AM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
When adding the oil make sure you have the plug screwed back in? can never ask a serious question on here for us less-motorized motor heads.
Fitz
fitzus1@gmail.com
Old 03-27-2014, 06:59 PM
Boy, we need to read this solution again!! Along with all the other AZ Cobra inputs...or is that "inputzs"? Thanks to the other "nice" members.
BB
Old 03-27-2014, 08:44 PM
mikiec's Avatar
The nice ones don't know you like the rest of us.
Old 03-28-2014, 12:12 PM
Like
And lastly, send mickic the bill for the new engine. Having been run for a week without oil (:
Old 03-28-2014, 02:33 PM
mikiec's Avatar
I have more bills than I can pay. I'll add his to that pile.
Old 03-28-2014, 02:35 PM
mikiec's Avatar
Hey, Bill... Did you ever get the seats done?
Old 03-28-2014, 03:34 PM
Default Seats
Mike...not yet. The guy is on holiday till next week. No hurry.
bb
Old 03-28-2014, 03:57 PM
Karl Bebout's Avatar
Chanmadd: "I like to mark the dipstick when the motor is upside down on an engine stand........mark just below the crank throw ............when its running there will be a quart or more in the top of the engine....."
This really had me scratching my head then it dawned on me that maybe the engines you work on have the dip stick tube mounted through the block. I'm most familiar with Chevies and their sticks are mounted through the oil pan. It would be impossible to see where the stick reaches with the pan resting on the underside of the up-side-down block. I've had only a few Chevy engines torn apart, over 'way too many decades, but I think I have a fairly good idea of how they are engineered. Both the good and the bad things. Thanks for making me think.
Karlos
Old 03-28-2014, 10:20 PM
Jesus...what did I start?
Old 03-30-2014, 01:32 PM
Danr55's Avatar
With Karl, it's not the number of engines he's taken down, it's the number of times he's taken down this engine/car. It's almost a career... Hi hero..
Dan in Arizona
CCX3209
Old 03-30-2014, 08:41 PM
Oh Danr: "With Karl, it's not the number of engines he's taken down, it's the number of times he's taken down this engine/car. It's almost a career'
What chew talkin 'bout? This engine went away only once, after 27K miles, and then only from something battering around on top of some pistons. All the other down time was due to an operator error or taking the car four-wheeling, not engine parts breaking or failing, like SOME PEOPLE's car...
Karlos
Old 03-30-2014, 09:09 PM
Danr55's Avatar
What chu talk in about? Chu tryin to say sumtin?
Dan in Arizona
CCX3209
