Like Tree1Likes
Old 09-08-2014, 09:04 PM
DWRAT's Avatar
Default expansion tank help/advise
My expansion tank has a crack where circled in red and leaking.
Any advise for a local repair person or what are my options.
Thanks
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 09-08-2014, 09:40 PM
mikiec's Avatar
My thoughts, clean the ares and re-solder it.
Old 09-08-2014, 10:00 PM
MaSnaka's Avatar
I have had mine repaired more than once. A competent radiator shop that still does solder work should be able to fix it up while you wait. Maybe pay $20. You may have to paint it though.
John
Old 09-09-2014, 03:55 AM
undy's Avatar
I was plaqued with leaking soft solder joints on my tank. I'd repair one and another leak would pop up. Being a HVAC guy I de-soldered my tank and cleaned all the soft solder off the joints. I resoldered the entire tank using grade III silver solder (15% silver) and 4 years later not the 1st leak.
Too many toys?? never!
Old 09-09-2014, 05:00 AM
Danr55's Avatar
If none of that works, come over to my garage and pick one of the three I have on boxes.. Seriously, silver solder is a good answer. Prevents leaks far better than softer TN/Pb solder.
Dan in Arizona
CCX3209
Old 09-09-2014, 06:53 AM
DWRAT's Avatar
Thanks Danr, I may take you up on a new one.
I am hitting a radiator shop today to see if it can be fixed.
I will let you know.
FFR MK1---Sold
No more Furds.
Old 09-09-2014, 08:23 AM
Default Hals
These guys did mine, then I spray painted it.
Hals Radiator Service - Glendale, AZ | Yelp
AZ Bob
Old 09-09-2014, 08:43 AM
DWRAT's Avatar
AZ Bob
Thanks Bob, the tank is now at Hals.
FFR MK1---Sold
No more Furds.
Old 09-10-2014, 07:25 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Great place to take a leak!!!
LMH likes this.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 09-10-2014, 10:43 PM
DWRAT's Avatar
Hals did a fine job and got it all sealed up for me.
I fought this leak for a while, first figured it was a leaky gasket, then leaky bolts then with a small mirror and a flash light I was able to see exactly where the leak was coming from, the tube to flange joint.
I did the job 4 times.
So far so good.
FFR MK1---Sold
No more Furds.
Old 09-10-2014, 11:23 PM
Jeff is the one that sent me to Hal's
AZ Bob
Old 09-11-2014, 10:38 AM
Karl Bebout's Avatar
"Great place to take a leak!!!"
"Jeff is the one that sent me to Hal's"
Jeff knows all the best places to take a leak.
Karlos
Old 09-11-2014, 11:06 AM
Fast289's Avatar
Cobra Make, Engine: FFR 289 FIA 347 Stroker
Karl,
There is algebra in that statement.
On another note, I had a guy George install a doggy door in the new home. He has a GTO and 57 Pontiac. Says he parks by you at Albertsons and Kmart shows. He said your car is loud.....
Dave from Chandler.
Old 09-11-2014, 01:38 PM
Dave, that guy's GTO and '57 Pontiac are both extremely nice cars. Very heavy on the bling on the GTO and the '57 is an exceedingly rare Canadian model. SWEET! He's a good one to talk about decibles. There's been times he's rolled in with the headers open on the goat. Plenty raspy.
Karlos
Old 09-12-2014, 03:58 PM
DWRAT's Avatar
Now there is a slight seep on the opposite end of the main tube.
Sent you a PM Danr.
FFR MK1---Sold
No more Furds.
Old 09-12-2014, 04:39 PM
Carry a tube of Alumaseal, just in case. It might do the trick, might not. At very least, it is a very good water pump lube.
Karlos
Old 09-12-2014, 06:20 PM
Danr55's Avatar
I got your PM and answered it. Alumiseal works as does Barrsleek but they may both clog your radiator. Run for a while and see if the seep stops, if not take it down and have it soldered and pressure tested. Silver solder is harder than lead/tin solder and will not leak.
Dan in Arizona
CCX3209
Old 09-12-2014, 06:54 PM
I second the AlumAseal. I carry it and have used it twice.
AZ Bob
Old 09-13-2014, 04:03 AM
undy's Avatar
I got your PM and answered it. Alumiseal works as does Barrsleek but they may both clog your radiator. Run for a while and see if the seep stops, if not take it down and have it soldered and pressuetested. Silver closer is harder that lead/tin solder and will not leak.
Just remember, with silver solder cleanliness is next to godliness. Make SURE all the soft solder is COMPLETELY removed before silver soldering. It's the best thing I ever did to my tank.
Old 09-15-2014, 08:54 PM
DWRAT's Avatar
No more surge tank problems soon hopefully.
I ordered a Kirkham billet alum surge tank with right side exit.
David Kirkham was very helpful.
Small Block Surge Tank???
FFR MK1---Sold
No more Furds.
