4Likes
05-22-2015, 10:24 AM
Cobra Make, Engine: 1965, small block 427/535 Ford Racing crate motor with fuel injection by Bob Reem
Update: Got the dar back this morning and I have only one word to say about what Bob did.......WOW!!!! Running amazing, instant throttle response. It was a combination of 3 things, O2 sensors were moved from collector to the last header tube on the passengers side about 10" away from the head, the spark plugs were way too cold (needed a hotter plug), and the vacuum pressure was a bit low. I rides great now.
Joyridin"....I do not have the side pipe mount on my headers. There is no flange to join the header to the side pipe. Mine are one piece weilded from the collector to the heads. They were custom hand made.
Thanks to everybody for chiming in and giving me an education on just how EFI works.
Joe
05-22-2015, 11:24 AM
MI
Great to hear everything worked out so well. I've been considering an EFI system too.
05-22-2015, 12:48 PM
Joe
Glad to hear it worked out I suspected it would. Two questions.
1.) You said the vacuum pressure was to low. I assume this means you had poor vacuum at idle because of the cam overlap.
2.) You said your headers and pipes were a one piece weldment? Is there a hole or a slot in the fender where the pipe passes through?
Again congrats I am glad it worked out. Please give us a 1000 mile update so we know if it is still going well. It would be a service for anyone considering the change.
Bill
05-22-2015, 01:16 PM
All's well that ends well. Congrats Joe!
Ed
05-22-2015, 07:18 PM
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
05-23-2015, 06:33 AM
Detroit Bill.....Yes I am assumuing the same as well, the vacuum was a little low due to the cam. The fenders both have a slot where the headers exit the engine bay and turn down the side of the car. They are wielded one piece from the collector to the head. The "baffle" tube seperates to open the headers. Bob wants the car back at 200 miles to check the settings just to make sure that all is well and no tweaking is necessary.
DW....No worries on the referral, worked out great and Bob is such a nice guy to boot. After seeing his shop and the quality work he does I knew that it would get done. I like the fact that it still has the peroid correct look of a carburator. Thanks again for the referral.
Joe
05-27-2015, 10:13 AM
I put the FAST 2.0 EFI on my 408 Keith Craft this past week.... Was easy peasy.. Runs like a champ now... Autocrossing with a carb is for the birds...
Kevin....
05-27-2015, 11:50 AM
Still have a bit of tweaking to do, but have to get at least 200 miles on the system the way it is now first. Running like a raped ape now.
05-27-2015, 10:27 PM
Cobra Make, Engine: FFR, 302, Trick Flow EFI
At some point it seems like everyone's car pays a vist to Bob's shop (at least those of us on the west side). He has a great shop and does excellent work.
05-28-2015, 07:43 AM
Thinking of going down to Chucks Speed Center and having the car set up on the Dyno to really dial it in. Bob tuned it on his laptop at idle. Would it make an improvement when being done at speed. I never had a car dyno tuned before and am in need of some thoughts. Bob wanted me to bring the car back at 200 miles to check all the settings. Have it dyno tuned or wait until after the 200 miles. Thoughts please.
Joe
05-28-2015, 08:19 AM
I wouldn't get someone else involved.
It could cause a big problem of "I didn't do that".
Let Bob tune it or have him recommend a dyno tuner.
I know he sent Sherm1 to a dyno tuner up north near CaveCreek somewhere.
FFR MK1---Sold
No more Furds.
06-02-2015, 04:24 PM
Cobra Make, Engine: FFR 1574 331 Blown
I have a modified Pro-M Racing system, it uses all my old sensors, old trickflow manifold, TB, etc except the O2 which are now wide-band with gauges. What I got was a modern Ford ECU, clealy marked wiring harness, Wideband O2's with gauges. There is a little setup with a laptop at the beginning very easy. There is a about 40 min video the website, good education on how Mass Air system work during an installation on a Fox Body Mustang. I had a little issue with one of the O2 sensor which was my own doing. I'm 99% sure I have it under control now after welding in a longer bung to protect the sensor and protecting the O2 sensor connector from heat and vibration. I was running a vortech supercharger, s-trim however the seals failed and I have it off the car now, I made zero changes to the computer, change my plugs one heat range hotter and that was it. Since the Pro-M system measures air going it doesn't care if I have a blower or not. I'm pretty happy with what I have, the support from Pro-M Racing has been great too.
Paul
AZ Cobras
