Like Tree2Likes
  • 1 Post By Gaz64
  • 1 Post By Danr55
Old 05-15-2016, 03:48 PM
Danr55's Avatar
Default New Solution to an old problem
As some of you are aware, I've had issues with my alternator making a horrible noise when I start my car. I've tried tightening the belt, tried soaping the belt this morning (No Joy) Tried buying a belt the same size without the interupted teeth.. still no joy. So I sat down and looked the whole thing over again.. Gues what? The belt that is the right size for the water pump and the crank pully is too small for the pully on the alternator. Bought a belt 1/8 inch wider without interupted teeth and problem solved. So, if you have March custom over-drive pulley on your alternator, make sure the belt fits the march pulley aand the waterpump and the crank pulley will handle it just fine..
Dan in Arizona
CCX3209
Old 05-15-2016, 05:03 PM
DWRAT's Avatar
Nice find Danr, I think that squeal would have driven me crazy.
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
Old 05-15-2016, 06:58 PM
mikiec's Avatar
Way to go Danr, at least no nuts were dropped down the intake.
Mikiec
Old 05-15-2016, 07:57 PM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
Great news Dan! Glad you found the gremlin.
- Robert
Old 05-15-2016, 08:05 PM
Gaz64's Avatar
An 1/8 inch wider, that's a huge stepup.
Guess what has happened to the drive ratio now.
I would replace the alternator pulley with some other brand that IS a match for your crank and waterpump pulleys.
What does March say about this?
Gary
cdnus likes this.
Old 05-15-2016, 09:46 PM
Karl Bebout's Avatar
Dang, glad you will finally stop making such OBNOXIOUS noises when you finally get your car started. Now, work on the driver...
Karlos
Old 05-16-2016, 06:15 AM
Danr55's Avatar
Karl, the owner has been making those noises for years and no cure has yet been found!
Robert McLinden likes this.
Dan in Arizona
CCX3209
Old 05-16-2016, 06:34 AM
Scotchman's Avatar
Cobra Make, Engine: FFR MK3/302/570 street avenger
And I thought that was your car backfiring
Old 05-16-2016, 10:01 AM
"And I thought that was your car backfiring "
His car's backfiring could never make your eyes water and your stomach retch that badly.
Talkin' paint peeling.
Karlos
