Old 12-08-2016, 08:48 AM
vettestr's Avatar
Default That time of year
Hey Gang, Just a reminder to check a few things on your Hot Rods. About this time of year I check for contamination or just replace brake fluid, hyd. fluid in clutch M/C and reservoir, engine coolant for acid or PH value and freeze point. Also check battery water level if possible and clean cable ends.
Brake/clutch fluids are flushed with new fluid if discolored or any signs of rubber dust in bottom of reservoir is visible.
Engine coolant gets a simple PH test strip check. I also test for any voltage present showing electrolysis is going on. I use green coolant and additive for anti rust and a WP lube that reduces problems. Not so worried about freeze point here in Phx. so 20* is plenty. I do find electrolysis in fair amount of cars I check for the first time. Ground problems most often the cause. PS... run test wire back to battery during testing. How to test for electrolysis | Vehicle Enhancement Labs
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 12-08-2016, 11:31 AM
Karl Bebout's Avatar
Thank you Jeff.
Karlos
Old 12-08-2016, 02:59 PM
Danr55's Avatar
Excellent advice. Thanks Jeff
Dan in Arizona
CCX3209
Old 12-10-2016, 03:58 PM
moore_rb's Avatar
Cobra Make, Engine: All original, with Chevy engine since 1964
Great reminders Jeff...
- Robert
