3Likes
01-14-2017, 03:26 PM
Step #1. Loosen set screw.
Step #2. Use at least a 36" long wrench
Step #3. Tighten the livinsheet out of it.
Step #4. Order Parts
Valve lash adjustment procedure, according to Danr.
Karlos
01-14-2017, 05:53 PM
Nope. They are hydraulics. The set screw snapped right above the oil port. Looks like the metal crystalized.
Dan in Arizona
CCX3209
01-14-2017, 08:58 PM
Next week?
Sunday: Crossroads Gun Show Mesa
Monday: Barrett-Jackson
Tuesday: Padre Murphy's
Thursday: Silver Auction
Saturday: Crossroads Gun Show Fairgrounds & Peoria Cruise In
Sunday: Russo & Steele
I avoid the Bonham, RM and Gooding since I couldn't afford them anyway.
This week is also Blood test and colorectal on Tues, Lunch at Heidi's on Wed, Ben Avery on Thursday night, Coffee at Panera and Solar City meet on Friday.
This retirement is killing me. I need to go back to work so I can rest.
AZ Bob
01-15-2017, 05:56 PM
az
But why did the set screw break instead of the rocker arm. And why did you need to adjust the valves, hydraulics usually don't need adjustment.
_____________________
01-15-2017, 08:48 PM
Car Nut,
"But why did the set screw break instead of the rocker arm. And why did you need to adjust the valves, hydraulics usually don't need adjustment."
Remember, this is Danr.
Karlos
01-16-2017, 06:02 AM
From initial.investigation, it appears that the thread root on the adjusting screw lacked the proper thread root radius creating a stress point. That combined with what is perhaps an errant hardening process combined to create a failure when torque was applied.
Dan in Arizona
CCX3209
01-16-2017, 07:35 AM
az
Cobra Make, Engine: ERA FIA, 396 Windsor Stroker (Formerly: Unique 427 powered by a 351W with mysterious innards)
Translation: The thread was stripped and he cranked down too hard on it and the damn thing broke.
The old saw says ‘If you want a thing done right, do it yourself.’ The true statement is ‘If you want it done your way, do it yourself.’ There are many flavors of ‘right’.
01-16-2017, 11:07 AM
"From initial.investigation, it appears that the thread root on the adjusting screw lacked the proper thread root radius creating a stress point. That combined with what is perhaps an errant hardening process combined to create a failure when torque was applied."
Its gettin deeper and higher. Where's my hip boots?
Karlos
01-16-2017, 03:48 PM
OK Hipboots, Check these out and see what conclusions you can draw.. I would be happy to entertain any other substainable theories.
Dan in Arizona
CCX3209
01-16-2017, 03:53 PM
Cobra Make, Engine: 65 Cobra w/351W
Dan, you need to lay off the protein shakes.
I'm not broke. I'm Hot Rod poor!!
01-16-2017, 04:33 PM
az
Tried adjusting them without loosening the locknut. Lefty loosey, righty tighty.
01-16-2017, 05:01 PM
Nope. Loosed all the locknuts then turned the engine over by hand.. One full rotation of the distributor.
Dan in Arizona
CCX3209
01-16-2017, 06:33 PM
az
You still didn't say why you were adjusting hydraulic lifters when you should not have needed to.
Karl doesn't think we are getting the whole story.
01-16-2017, 06:43 PM
Karl is and always has been a conspiracy theorist. You got the whole story.
Dan in Arizona
CCX3209
01-16-2017, 08:12 PM
Cobra Make, Engine: All original, with Chevy engine since 1964
The only conclusion I can draw is that it definitely looks like a Ford part...
- Robert
