November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree2Likes
  • 2 Post By NoVA Cobra
Old 03-20-2024, 05:10 PM
NoVA Cobra's Avatar
Cobra Make, Engine: SPF1439 427FE s.o.
Default Superformance driveshaft
So I had a little wiggle in rear u-joint so I thought I'd replace it. After removing driveshaft and front u-joint - I realized the rear u-joint caps are pressed onto driveshaft without retainer rings and are non-serviceable. So how to source a replacement driveshaft? Or is there another solution? I attached pics of the numbers I see, but I can't find anything to match. I can't find the front u-joint as well based on the pic, but I figure I could just measure it to get that one.
Superformance 1439 w/427FE side-oiler. 2007 GT500 40th Anniversary CSM07XL0078. 2007 GT500 40th Anniversary CSM07XL0085.
Old 03-20-2024, 05:58 PM
eschaider's Avatar
Whatever gets pressed in can also get pressed out.
If that is an unacceptable alternative, a driveshaft shop can cut the rear universal joint casting off the drive shaft (you can, too, and save a little $ if you have a lathe). Replace the press-together version with a retainer clip version, and don't worry—be happy.
Old 03-20-2024, 06:20 PM
And if you're looking for a shop that can handle that little chore I would recommend Machine Service, Inc, in Green Bay. They did mine. https://www.machineservice.com/
Old 03-20-2024, 06:40 PM
chucks1's Avatar
Cobra Make, Engine: SPF, 395 Stroker
I recollect back in the good old days when I used to know how to use a vise and a couple sockets, pressing old u-joints out and new u-joints into place quite frequently.
If the vise and sockets didn't do the trick on old rusty joints, a little swat with a ballpeen hammer on the side of the drive shaft would break them loose.
Of course I also recollect the cars I drove were barely worth more than a set of new u-joints to begin with . . .
Old 03-20-2024, 07:32 PM
sunman's Avatar
Is that possibly an internal clip u joint for the driveshaft side?
You can’t see from pictures…
Chaney Shores Studio
Old 03-20-2024, 07:36 PM
MasterAnubis's Avatar
It's been a while, but I had my Galaxies driveshaft U-joints replaced and shaft balanced at Dick's Drive Shaft Exchange on Washington in Phoenix.
I was still curious about your u-joints so I am still trying to see if I can find PNs. They should be a pretty standard part.
Shawn
Tempe, AZ, USA
Old 03-20-2024, 08:31 PM
John, it's SQUEEEEEZE on out, one end a a time. As Chuck said, a couple sockets and a hefty vise with do the trick in lieu of a hydraulic press. Smaller socket to match the diameter of the joint's cap and the larger one big enough for the cap to clear it's insides as you press.
Old 03-20-2024, 08:39 PM
sunman's Avatar
Looks like an internal clip, it’s hard to see on my IPhone
The open end of clip is shown
Definitely check
Old 03-21-2024, 04:49 AM
Senile Club Cobra Member
https://www.bing.com/search?pglt=43&...ANCMS9&PC=U531
Any Fleetpride can rebuild that in 20 minutes
rick@autoventureusa.net
Old 03-21-2024, 06:18 AM
NoVA Cobra's Avatar
Definitely check
I thought inside clip as well, but there's none that I can see. I don't have a big enough vise, but I banged it pretty good with said sockets with no progress. I tried a ball joint press with no luck. Almost seems the caps are pressed into a seat. I'll try Dick's Driveshaft mentioned and get it done right.
Old 03-21-2024, 08:53 PM
John, see if the shop will let you watch so you'll know if there's a next time.
Old 03-22-2024, 02:51 AM
Cobra Make, Engine: ERA 289 FIA #2102, Keith Craft 427W
If you need a back-up to Dick's Driveshaft...Arizona Driveshaft in Mesa on Southern Ave does great work as well.
Best of luck
Old 04-01-2024, 09:54 AM
NoVA Cobra's Avatar
So it was an inside clip. Feel like an idiot. Simply could not pull it out - could not see open end. Dick's is now https://phoenixrackandaxle.com/ and they replaced both u-joints then balanced. Happy again.
DanEC and JTMCOBRA like this.
Old 04-01-2024, 05:53 PM
John, glad you got fixed up just in time for the Picnic on 04/06. Also, are you going on the RT 66 Fun Run this year. 05/03-05?
Old 04-02-2024, 02:15 PM
Thor maine's Avatar
Put the HEAT to it ? Maybe it is the GM nylon injection retaining system?
