Old 10-22-2002, 02:07 PM
Default Just when I got it going again!
Well after I got my a$$ back from Mike on Saturday for not fixing my Cobra sooner. I got up early and fixed the headlight, Mike was a right a ground wire had broken loose. It was stubborn but after cussing and throwing a tantrum on the ground in my garage, I got it hooked back up. I then continued on to locate my mass air sensor. My Mustang book did not mention it (interesting) I found it down by the K&N filter. Took out the filter and mass air sensor. Sprayed it down with carb/manifold cleaner and cleaned the K&N just for kicks. I threw some in the manifold and lubed the choke for more kicks.
Now the time for the test-drive to see if it was still backfiring when I hit the gas and if it was still losing power. Started it up, ran a little rough from all the carb/cleaner I sprayed down the throat. Then it was fine……….went out on 43rd Ave and so far so good…..turn right on Bell going West and decided to punch it in second……felt like my whole backend was vibrating out and was wheel hopping like crazy…..BACK TO WHAT IT WAS and no backfiring! It still gurgles when I coast and let off the gas. But it has always done that since I took off the cats.
Well I am as delighted as a stud during breeding time. Then……………..a strange noise…..that gets louder…….sounds like a clicking coming from the tire….. well a I drove home slowly. I located the clicking to the center of the wheel. Appears either I have too much grease in the bearings or the bearings are bad…………another thing to come between me driving my Cobra……..
Today on the way to work my oil pressure in my Jeep shot up to 80 and I started smelling oil. The last time this happened was the oil pressure sensor broke. Appears it broke again. ANOTHER thing to mess with before I can get to my Cobra. AHHHHHH
What is your local Socialist Group planning now?
Old 10-22-2002, 02:29 PM
mikiec's Avatar
Jason,
Well, finally you have your priorties straight.
Is the wheel noise coming from the front or rear wheel?
Saturday, I'm heading over to a fellow FFR owner who is just starting his build. You want to tag along to see what your car started out as? If yours is not fixed I'll let you ride with me.
If you make the 5 & Diner tonight we can talk about it.
Old 10-23-2002, 09:44 AM
Yeah I want to go! Let me know the time. I don't think I have been in your car. I will have to hitch a ride and see what you got!!
Old 10-23-2002, 09:53 AM
mikiec's Avatar
Jason,
It will probably be after 1 PM. We have the Breakfast run to tortilla flats in the morning.
Old 10-23-2002, 09:57 AM
Give me a time when you will be back in town. If the guy's place is too far, I can meet you at a certain time.
Old 10-23-2002, 11:10 AM
mikiec's Avatar
Jason,
The builder is about 10 miles from us.
We are meeting those that are going on the run at the 60 and Idaho Rd. time 8am for the run to Tortilla Flats, just north of Apache Junction. We should be done with breakfast around 11. Then a 1 hr drive back to our side of town.
