Old 11-23-2004, 11:09 AM
vettestr's Avatar
Default need coolant xfer pump 12 VDC
I need a good engine coolant transfer pump. It will pull double duty to supply heater in winter months and supply remote mounted cooler for summer needs. I have used fuel pumps with fair results and think there must be better product out there. The NASCAR guys use a pump but cost about 300 bucks and that just seems wrong. I need some ideas here guys.... help. 12VDC pump for 250 degree max petrol. based liquids ????
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 11-23-2004, 12:52 PM
Big-Foot's Avatar
Cobra Make, Engine: RCR GT40 #45
Hi Again Jeff,
The pumps we use for Tranmission and Differential coolers are pretty expensive, but they don't leak and they are up to the task. For the purposes you have, I am curious why you are not considering using the water pump, itself, as the "pump" to circulate the engine coolant. The port on the water pump itself is the input side - coolant flows into the pump because (rule here) "Water Pumps Suck".. Run your hot side (output from the engine) from the head at back of the intake manifold.
Now - if you are talking about recirculating engine oil from/to the sump, you will need the high dollar pump or you will have a mess on your hands (and everywhere else).... Fuel pumps will only work for a short time. Once you put 250* oil through them, the diapraghms and/or shaft seals get hard and crack - leak city....
Regards - Randy
RCR40 #45 http://www.GT-Forty.com
Old 11-23-2004, 04:35 PM
Cobra Make, Engine: SPF 2682, Roush 427
Moroso makes a pump for such fluids. I believe it is advertised as a differential cooler pump.
Old 11-23-2004, 07:41 PM
vettestr's Avatar
Thanks for the ideas, I am running an external cooler mounted basicly under the passengers seat area for extra cooling for those stuck in traffic moments. This requires a pump to move coolant through system and return to block. The ON time is limited but need a pump that performs in these conditions.
Jeff Classic
