February 2026
Old 10-29-2006, 04:52 PM
Cobra Make, Engine: SP1909 392 Stroker
Default AHHH Nuts, I did it again
A quick run up to desert moutain and yup I did it again.. enjoying the nice night and it stalled, wouldnt start and had to wait and have it towed..
I would post a pic but dont know how
Brian,
Thanks so much for you help on saturday. I am going to look at the head gasket tonight. And yes.. coolant is leaking .. ughhhhhhhh
I hoping it will be ready before the fun to tuscon in November.
Karen
Old 10-29-2006, 05:15 PM
Clois Harlan's Avatar
HeyBrian what was it doing when it stalled? Turn over but not fire? Did it get hot?
Clois
"Let's roll"
"Be part of Something Good
Old 10-29-2006, 05:29 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Clois
Clois, I think Karen is the author of this thread!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 10-29-2006, 06:30 PM
Cobra Make, Engine: Superformance #1683, Roush 392
Karen,
To upload pictures you can click on the picture of a camera beneath your name and that'll get you started. I joined the forum recently and I think that worked for me. I also have a SPF with a 392. Mine's a Roush engine, what about yours? How many miles do you have?
Bryan
Old 10-30-2006, 11:54 AM
BPWilliams's Avatar
Cobra Make, Engine: none
Karen,
Before you start rippin into your baby here are a couple of things that I would check rightaway...
1) check for water in your oil, Use dip stick or drain it...
2) check you radiator to see if you have oil in your water...
3) Do a good visual and make sure your outer block is OK.
4) Pull your valve covers and check your valves and springs.
5) Do a leak down test (best), or compression test (first remove all the plugs to let any water that might be in the cylinder(s) out)
6) The leakdown should identify where the problem is and on what bank.
7) fix it, and we will see you on November 18th....
I was sorry to see that your car was down, take it easy on those Freeways you don't need to beat all the cars you come up on I am going to start calling you Monica....
Let me know if you need any help!
Brian
There is No Replacement for Displacement.
U.S.A. All the Way!
Old 10-30-2006, 12:40 PM
Karl Bebout's Avatar
Karen, you certaily got lucky if you were having engine troubles and Brian came along. He's had 'way more than his share of "opportunities" to explore the innards of his engine. His advice about not needing to beat everything on the road is sage since he does tend to flog the beJesus out of his car from time to time. Hope you are lucky enough to find something minor and can get back on the road soon. The weather is 'way too nice to miss.
Karlos
Old 10-30-2006, 01:08 PM
OOPS! Sorry, Karen I miss read the message. I hope whatever the problem is it can be fixed in an afternoon.
Clois
"Let's roll"
Old 11-02-2006, 10:02 PM
John-Tucson's Avatar
Hey Karen, sorry to hear about your problems. To bad that you will miss the Challenge on the 11th. John
Old 11-02-2006, 11:19 PM
Click on your CAMERA icon, on THAT page click on "Upload Photos".
Of course you have to KNOW where the photos are stored within your hard drive, thats the tricky part.
Hope it's just a simple blown head gasket and your back in the saddle shortly.
Old 11-09-2006, 02:25 AM
Default so far
After some investigation it looks like it the fuel pump! Hopefully I will have it ready for the 11th challange but we shall see..
Old 11-09-2006, 02:37 AM
Just say the thread.,. no 11th challange dope!
Old 11-09-2006, 09:08 AM
mikiec's Avatar
Karen. We gave you an extra week to get it fixed.
Hopefully we will see you on the 18th.
Old 11-12-2006, 10:10 PM
BPWilliams's Avatar
Karen,
So whats up? whats wrong with your car...? we all want to know the mystery is killing us.....
Brian
U.S.A. All the Way!
Old 11-13-2006, 08:38 PM
It looks like the fuel pump.. I called and talked to the guys that built my pump.. i need the pressure .. ordered it and looks like the wrong pump.. ugggghhhhhhhh.. I am headin out tonight to lift up the car and see what all i need to do.. I am in a rush for the 18th and i know the hour glass is a tickin...
i get one car running and the other goes out.. uggghhhhhh.. and i am still crossin my fingers that it all it is..
Karen
Old 11-13-2006, 09:06 PM
Brian,
You dont happen to know what kind of fuel pump would you?
Thanks Karen
Old 11-14-2006, 11:41 AM
BPWilliams's Avatar
Is it mounted in the rear of the car or off the front side of the motor?
If it is in the rear it is modt likely a Holley Blue
If it is on the moter could be anything from stock to an Eddlebrock fuel pump.
Make sure you look at the connections and check the size of the lines and the direction that they enter and exit...
Brian
U.S.A. All the Way!
Old 11-15-2006, 07:46 PM
Brian,
Thanks brian.. the fuel pump is in the back. I got the holley red but it looks completely different.. Once again I am at square one... It is a tight squeeze under the car. I am unsure what kind it is.. could the holley red work at all? and i thought the blue had the regulator on it? sorry so new at the cobra stuff.. any input would be helpful. If I tap on the fuel pump it releases some but not enought to get me anywhere.. so its stuck in the garage.. ugggghhh..
we are working extra hard on trying to get it done for saturday... i would hate to have the drive the 62 lincoln! HA
Karen
Old 11-15-2006, 09:08 PM
vettestr's Avatar
Karen,
I can answer a few of the ??'s on the fuel pump and what possible alternative pumps may work for you. What is the latest? Give me a call as I am also here in the valley. Hope I can help. Jeff C 602 402 8504
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 11-15-2006, 09:32 PM
mikiec's Avatar
Karen..
Call Jeff.
Old 11-15-2006, 09:37 PM
Thanks Jeff,
I will give you a call tomorrow morning as it is late. I would appreciate any help you may give me.
I do appreciate everyones help and knowledge..
karen
