Old 01-07-2009, 09:37 PM
Original Shelby Owner
Cobra Make, Engine: CSX 2252 sold 3-08, 1986 AC Cobra MK IV #185
Default Best Dyno shop in the Phoenix area
Please give me your opinion who has the best Dyno shop in the greater Phoenix area. Includes best work and prices.
Is it time for a "Club Dyno day" in the next few months?
Old 01-08-2009, 09:15 AM
Karl Bebout's Avatar
I could go for a dyno day. I've never put my car through that and it would be interesting, and probably disheartening, but certainly fun, unless I had the same results that Fitz had a couple years ago.
Karlos
Old 01-08-2009, 12:56 PM
Danr55's Avatar
Don't know where, but I'd be up for a Dyno Day..
Dan in Arizona
CCX3209
Old 01-08-2009, 01:28 PM
mikiec's Avatar
The last time we did a Dyno day, Paul G. brought a grill and did the burgers and dogs.
I was going to setup a day at Anthem but..........
If you find a place and they can accomidate us on a Saturday I'll get an email out.
Old 01-08-2009, 02:44 PM
greg schroeder's Avatar
The guy at AZ Dyno Chip (ADC), http://www.arizonadynochip.com/ , knows his stuff. It's a Dynojet, so inertia type dyno, but he really does knows how to work the thing and tune. Probably shouldn't be tuning on a dyno day though. He'll produce graphs corrected to SAE value with zero smoothing, so they're realistic. We had a dyno day a while back at AZ Dyno Chip (ADC) It went really smooth, efficient and was really fun. The dyno day we had at Arizona Dyno Chip had the guy that runs the place making dogs, burgers and chips with pop. He's really a great guy, quiet and modest, but you can see his brain working while he works the dyno. He loves Fords too.
http://www.arizonadynochip.com/rates.php
Dynojets, when used correctly, are going to come out very close to HP calculated from trap speed of 1/4 mile. Definitely the most fun for a dyno day.
off idle drag pass, DA 750ft.
Old 01-08-2009, 05:34 PM
ItBites's Avatar
Default I used XACT Dyno
A fellow named Tim runs XACT. His is a real fluid dyno, so none of the problems inertia drums create wrt spin-up rate. His dyno bolts to the hub, so no tire spin on big power cars, resulting in errors. No tie downs and sand bags for weight/traction needed. I wouldn't trust an inertial dyno, unless I had no other local option. Tim has a weather station built-in for true SAE corrections. He's also a real sharp tuner who found I make the same power at 28 deg advance that I get at 32, 34, or 36, so we backed the timing to where I'll never detonate! He can handle the power from any of the local Cobras; he tuned mine to 540 rwhp in 2 hrs. The thing that was really cool was that he could set in the computer the time to ramp from 3000 to 6000 rpm (we used 6 sec) and just floor it, the computer on the dyno controlled the load to linearly ramp the rpms up. Not like the old days!
E. Wood
ItBites
Old 01-08-2009, 08:09 PM
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
Sounds good to me, count me in!
Old 01-08-2009, 09:06 PM
Fitz's Avatar
Cobra Make, Engine: FFR Mk 3 408 530 - 585 T- mustang Dyno at B&R
Sounds good too but I am lost.
Gordon, where is a good place other then Dyno Comp in north scottsdale.
They are pricey too.
Remember, everyone will be disappointed in the results...always are.
Fitz
fitzus1@gmail.com
Old 01-09-2009, 06:30 AM
Here's a short video of a few cars from the last dyno day I went to at Arizona Dyno Chip. Seriously a good place for confident results with a good guy running the dyno which knows what he's doing. The video represents a Ford GT as stock, but I think it had a pully. All the other cars are highly modified. We've had all these cars to the drag strip and the trap speeds come out pretty much dead on to the results. I really trust this place.
http://www.youtube.com/watch?v=mOSD9vlnRqE
Old 01-09-2009, 07:22 AM
Rick Parker's Avatar
I had read that a local Ferrari shop was going to combine with Anthem's, did that ever materialize prior to?
Old 01-09-2009, 08:18 AM
ItBites's Avatar
Just a thought, but why don't we go drag racing again instead? It certainly showcases power output and is more fun than just spinnin your wheels on the roller. The big winners still have braggin rights (Karl and Greg). Fast timeslips have more cache than dyno sheets anyway...
Any takers?
E. Wood
ItBites
Old 01-09-2009, 02:10 PM
I'm good to go for either. I found that the lower brackets off the differential housing for the lower bar of my 4-link, were badly bent to the right. I've gotten them pretty well straightened out and will thoroughly gusset them. I'm sure I'll have to work at adjusting the suspension again to keep the car going straight. I like the idea of the fluid dyno, but would rather do that one for actual tuning rather than just getting bragging numbers.
Karlos
Old 01-09-2009, 02:53 PM
Cobra Make, Engine: Factory Five, LSx Block
Send a message via ICQ to Tails Send a message via AIM to Tails Send a message via MSN to Tails Send a message via Yahoo to Tails
Another vote for the Keith and his crew at ADC (Arizona Dyno Chip)..
Tails
Daniel
FFR MKIII Roadster Complete Kit, 3-Link, GM LSx Block, T56.
Build Pictures
Build Blog
First Start
Gokart
Let's Take A Ride
Old 01-09-2009, 04:29 PM
ItBites's Avatar
Fitz,
I was NOT disappointed after tuning mine on the dyno.
E. Wood
ItBites
Old 01-09-2009, 05:14 PM
Eric, I'm sure you weren't disappointed with the numbers you pulled. You built your own motor and didn't have somebody telling you that you'd have huge numbers, after paying them huge dollars.
Karlos
Old 01-14-2009, 10:22 PM
Fitz's Avatar
Well of all the ...
Fitz
fitzus1@gmail.com
Old 01-15-2009, 07:42 AM
mikiec's Avatar
Sounds like ADC is the place to go. Al we need now is for someone to call them and get some prices and a date.
Old 01-16-2009, 08:30 AM
It makes for a nice dyno day.
Old 01-16-2009, 03:27 PM
Count me in but it will be another 6 weeks before I can get a drieway to get my car out of the garage. I am anxious to see how Roush's numbers stack up against an independent dyno
Old 01-20-2009, 06:13 PM
If you go I'll be there. I'd like to see that on the dyno for sure.
Which exhaust do you have on your CSX?
