Old 08-21-2009, 02:23 PM
vettestr's Avatar
Default computer ? about RAM
I wanted to increase the RAM in my HP Pavilion N5415. It has 2 RAM slots but only came with one 256MB RAM chip installed so I have an open slot. HP says I can install up to a max of 512MB.
When searching for another (256MB PC-100 SO DIMM 144 pin) chip set I could not find anything in stock. They did have 2 with a little faster rating or (256MB PC-133 SO-DIMM 144 pin for laptop) at less than 1/2 price. Will they work? http://www.computermemoryoutlet.com/...415-memory.htm
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 08-21-2009, 03:40 PM
vettestr's Avatar
The RAM I just removed was a 256MB PC-133 and not the PC-100 the HP website said would be installed. I then installed 2 new 256MB chips and booted system up but it would not open to the normal desk top screen and remained a dark screen. ???
Jeff Classic
Old 08-21-2009, 03:46 PM
Hollywood's Avatar
Cobra Make, Engine: 1965 FFR MKII STROKER 514
you need two of the pc 133 ram. i may even have that at home, i will check.
give me a call or email me.
Old 08-21-2009, 04:16 PM
vettestr's Avatar
Jim,
I did install 2 @ of the new chips. The one I removed was already a 133 but choose to install the new pair without luck.
Jeff Classic
Old 08-21-2009, 05:00 PM
FatBoy's Avatar
If you go to www.crucial.com, there is a free scanner that will scan your PC and tell you exactly the type of RAM you require and then give you a price as well so that you can order it. We regularly use it to identify the correct RAM for client's PC's.
Paul
Old 08-21-2009, 05:35 PM
vettestr's Avatar
Paul,
That is a cool site, thanks. It appears I do have the correct RAM or same as already loaded and working. I will keep reading and looking for issues. Thanks Jeff C
Jeff Classic
Old 08-21-2009, 05:50 PM
Mulv's Avatar
Cobra Make, Engine: Cobra-less for now..
did you try putting the old stuff back in? Maybe the new DiMMs are bad ..
It's under a big W, a big W see?
Old 08-21-2009, 06:29 PM
vettestr's Avatar
Yep,
She works as before when I install the original RAM back in but NO combination of new and new /old.
Jeff Classic
Old 08-21-2009, 07:51 PM
Danr55's Avatar
Jeff, When was the last time you cleared your browsing memory or defraged your C drive?
Dan in Arizona
CCX3209
Old 08-21-2009, 08:16 PM
vettestr's Avatar
Hey Dan,
I keep her pretty clean for speed reasons. I am a big fan of CCleaner , Cookie monster, RegCure etc.. plus I did a clean and burn with delete all but last couple of restore points and then the defrag just before attempting this.
Jeff Classic
Old 08-21-2009, 08:23 PM
Hollywood's Avatar
easier answer, just get a 512 and scrap the 256 idea.
