09-08-2009, 11:15 AM
Wheel Balance ?
Where is the best place to place the weights?
What is the best way to balance?
09-08-2009, 11:29 AM
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
inside of rim on the flat part with adhesive weights.
High speed is best.
09-08-2009, 12:05 PM
Oh
That's where mine are. Stick on weights,
Jack
XSSIVE .....
09-08-2009, 12:39 PM
Best place.. On the wheel. Best way to balance...evenly.
Now that the smart assed stuff is out of the way.. The best place to place the weights on a wheel is evenly distributed on each side. The farther off the centerline of the wheel, the less weight is needed to effect the balance. The best way to balance is under dynamic load. Spining the wheel while placing it under a simulated load from a vehicle.
Dan in Arizona
CCX3209
09-08-2009, 01:04 PM
Why did I know that Danr could not resist.
Karlos
09-08-2009, 03:27 PM
GA
Cobra Make, Engine: BDR - 351 / 385 hp
Mike,
I struggled with balancing on my 15" BFGs for quite a while. I finally gave in & let the shop install clip-on weights on the rim instead of the adhesive weights. Wow, what a difference! The tires are still junk, but at least the vast majority of the vibration is gone. The clip-on weights don't look that bad to me now.
Speedy
09-08-2009, 09:35 PM
Cobra Make, Engine: Cobra-less for now..
Use the adhesive weights in the centre of the wheel but be sure and put race tape over them or they will fly... there are a couple of places in town that have rolling road balancers and those are really the best..
It's under a big W, a big W see?
09-09-2009, 05:02 AM
Mulv, Where are those places with the rolling road balancers?
Dan in Arizona
CCX3209
09-09-2009, 06:06 AM
6th Generation Texan
09-09-2009, 06:14 AM
Road Force Balance
Check out locations for the Hunter GSP 9700 Road Force Balance Machine:
http://www.gsp9700.com/pub/search/FindLocations.cfm
I have oversize tires on my SUV (Bridgestone Revo's on 17" Cobra "R" rims) that are huge and heavy. Having them road force balanced (with stick-on weights on the inside only) made a world of difference. No shake or shimmy up into triple digits.
Pulled the PSE FIA wheels and BFG's off my ERA, and was going to take them in, until I saw that I only had 3/4 oz. weight on the worst one. No noticeable vibrations, so I decided to leave well enough alone, and did not have them re-balanced.
regards,
Jeff
CobraJeff
ERA P 202
09-09-2009, 07:25 AM
Isn't that just like Mulv... Always teases but never delivers.   And we wonder why Nancy has stayed with him all these years. That gal must be a saint.
09-09-2009, 08:12 AM
AZ.
Mikie,
Dicount Tire can do road force balancing. Below is there phone number and location. I always work with Andrew. He is one on the store managers. I believe it is 15 bucks extra.
Discount Tire
(602)978-9686
(FAX) 938-5490 4455 W Bell Rd
Glendale, AZ 85308
Map discount tire phoenix bell
09-09-2009, 10:39 AM
Jeff,
That is the discount tire I always use. It has taken as many as 3 trips to get the BFG's balanced on their road force unit.
09-09-2009, 06:22 PM
Originally Posted by mikiec
Jeff,
That is the discount tire I always use. It has taken as many as 3 trips to get the BFG's balanced on thier road force unit.
Maybe if you bought some tires that are actually round that wouldn't happen... try Yokohama , BFG's are not great. Not to start the stupidity factor but BFG's are French tires after all...
I don't have all day to screw the pooch on the internet like the rest of you, however the guy I use is on the south side of University one block west of the 143...
09-09-2009, 06:49 PM
Steve,
I agree with you on the BFG's.. But that's all I can afford. And not many make the size's I need. Fronts 235/60/15 rears 275/50/15 or 295/50/15.
That does not leave much of a choice. And I'll not go to 17inch rims.
09-09-2009, 08:44 PM
AZ.
Mr. Mulv,
So who the hel! you trying to convince you are quicker at pooch screw'n than the rest of us? Have you ever taken a moment to consider the pooch? Maybe the poch likes an all day screw! BTW ...I don't want to hear what you do to some guy on University thats just sick!!
09-10-2009, 07:17 AM
Kah Ching..............
09-10-2009, 09:08 AM
Mike,
Same answer I gave you over at the FFR Forum.
Road Force balance off the car. If that doesn't do it, find a shop (and they are few and far between) that will do the balance on the car.
That WILL do it!
09-10-2009, 09:44 AM
I've never had road force balance not work 100% for me.
That machine will make you a happy driver for sure.
Dan
FFR MK1---Sold
Superformance #884 --- Sold
No more Furds.
09-10-2009, 01:16 PM
Ok, I agree with the road force balance. I'll try to find a shop that does the the balance on the car.
Now for the weights? I have heard they are best done on the outer most mass. IE: the outside of the rim near the beads. I know most of us have the weigths done on the inside for asthetics reasons. I do not mind them showing.
Opinions????
