Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
Like Tree2Likes
  • 2 Post By 750hp
Old 01-26-2020, 06:46 AM
Default Butler or not?
This Cobra is for sale locally. Seller dosen't know what the Mfg of the kit was. I'm thinking it is a Butler. Can anyone tell from the pics if it is a butler or not?
Have additional pics I can send. Wouldn't load in post.
Also how ins the room in a Butler?
Old 01-26-2020, 06:53 AM
Cobra Make, Engine: B&B Ford FE from Southern Automotive
Looks like a West Coast to me.
Old 01-26-2020, 06:55 AM
joyridin''s Avatar
Certain things look like it, but certain things do not. The dash doesn't look right and neither does the gas filler location. Without more info, it is hard to say. A Butler would have a Jag IRS, and a MG front end. The shifter will come out of the tunnel right about at your elbow, although that may depend on which trans is in it.
If you do a search through the archives, there are posts telling you how to check. There should be a number on the frame I think on the drivers side behind the front wheel.
It could be an Arntz, but you would need more pics of the interior and engine compartment.
Old 01-26-2020, 07:05 AM
It does have a Jag rear & MG front end
Old 01-26-2020, 01:50 PM
cycleguy55's Avatar
While the roll bar is very similar to my WCC, there's not enough 'droop' in the rear fenders, nor are they wide enough to be a WCC. The dash is also very different than WCCs. Mine also has beehive taillights, not tombstone - though that's minor.
Brian
Old 01-27-2020, 05:32 AM
joyridin''s Avatar
More than likely it is a Butler or Arntz. As mentioned, if it is a Butler, did through the old posts and there are numerous posts stating how to find the serial number on a Butler. Arntz never used numbers, so if the number is not there, it is probably an Arntz.
I could be wrong, but I do not recall ever seeing a Butler with the gas tank inlet where that one is located. I know Arntz put a tank in that location. Either way, you would not go wrong. What engine does it have?
Old 01-27-2020, 08:17 AM
A couple more clues. It has 10-79 welded on a chassis cross brace and G+R welded on anouther brace.
I also have a VIN, but dont want to post. Is there somewhere I can look up the VIN/SN?
No letters preceding the numbers
Old 01-27-2020, 10:48 AM
joyridin''s Avatar
I would have to crawl under my car, but I am pretty sure my Arntz has the same thing welded on the frame with roughly the same date.
More than likely, it has a VIN from a certain state. You would have to contact the BMV in that state and do the research. My car originally came from California, so it has a California VIN plate. The VIN is pretty worthless.
As mentioned, if it were a Butler, it would have a serial number on the frame behind the front wheel. Arntz had nothing.
Old 01-29-2020, 01:45 AM
750hp's Avatar
I see a whole lot more Butler Cobras with internal trunk hinges than Arntz.
joyridin' and Roncal1 like this.
Old 01-30-2020, 04:08 PM
joyridin''s Avatar
Hmmm...my Arntz has internal hinges. I never paid any attention either way. Now I have to start looking.
Old 02-03-2020, 06:37 PM
Cobra Make, Engine: Arntz
My Arntz has external trunk hinges
