Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Arntz/Butler Forum
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-11-2003, 02:31 PM
Monster's Avatar
Cobra Make, Engine: Arntz/Bennett, FE with lots of shinny parts that make it go fast
Thanks Pete.
I'm am unfortunately a veteran of the process (10+ yrs european import mechanic thru HS until I got out of collage). The problem is that I believe that the air is in the rears which I can't dangle because they are solid lines. The routing is very high up the frame and then returns down to the cross-over at the mid frame like an inverted "U" (poor installation was already inplace when I got the car but I didn't notice it until now). I'm looking into installing "SpeedBleeders" on the rear but I need to remove them tonight so I can get the right ones.
Thanks again,
Mike
Old 08-11-2003, 05:55 PM
Best of luck with it. I always find that if you continue run into obsticles, Scotch helps
Rate This Thread:
