Go Back   Club Cobra > Club Cobra Tech Areas > Transmission Talk > Ask Mike Forte (Forte's Parts)
Old 12-17-2012, 07:05 AM
Default tremec oil
I recently purchased an older superformance mk III. it has a tremec tranny, and the ony number i can find is on the case. Tremec MSK 11734. can anyone tell me which trans. i have, and more importantly, what is the correct oil for it. tks.
Old 12-17-2012, 08:02 AM
Cobra Make, Engine: Backdraft, Coyote
I believe it is a 3550, if so then it uses GM syncromesh.
Web site has lots of info: http://www.ttcautomotive.com/English...cts/tremec.asp
You can also call phone jeff at tremec to verify:
1-800-401-9866.
Old 12-17-2012, 11:01 AM
Default tremec oil
thanks for the reply, helps out
Old 12-17-2012, 02:40 PM
scootter's Avatar
It is the GM Syncromesh oil. I changed mine out to Ultra Shift from Performance Unlimited. Cobra Valley's Chemicals - Ultra-Shift Transmission Lubricant
Watch out when you go to change the transmission oil when warm. It isn't much thicker then diesel fuel and comes flying out the hole!! I learned the hard way and got oil everywhere!!!
Scott
Old 12-18-2012, 05:18 AM
Bob In Ct's Avatar
Tremec recommends GM Syncromesh. I used Redline MTL for 11 years with no issues.
Old 12-18-2012, 07:14 AM
I tried the Cobra Valley's Chemicals - Ultra-Shift Transmission Lubricant from Performance Unlimited.
Shifted like crap.
Went to Gm syncromesh and shifts way better.
Old 12-18-2012, 12:18 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Ultra shift!!!!
I agree - great shuff.
Tru
Old 12-18-2012, 12:43 PM
DAVID GAGNARD's Avatar
17 years and counting.........no problems with Redline MTL......
DAVID GAGNARD
Old 12-18-2012, 06:11 PM
Cobra Make, Engine: unique 427 351W
i have a tremec tko a few years ago i was having some difficulty shifting, i was considering changing fluid brand. i talked to a tremec tech who told me they recommend using only mobil 1 synthetic transmission fluid.
