Old 10-05-2009, 05:25 PM
Default Garage Update # 3
Hi There,
While I was at the Nationals there has been progress, the weather was abit better in Victoria for a change
Side Fence line
Other Fence Line
Over View
Where's my backyard
Todays Job
At 6.30am today the steel arrived...there is a bit of rain around today so they might be held up.
HAPPY STIFFY
Old 10-05-2009, 05:40 PM
boxhead's Avatar
Stiffy, have you got an area of the slab (where hoist is going) that is the required thickness?
And if so are they going to set the floor mounting bolts in the concrete or are you going to dyna bolt it down?
Cruising in 5th
Old 10-05-2009, 06:28 PM
Default Hoist
Boxhead,
the plan is for 3 x 4 posters (2 for storage and one on casters) the 2 poster will be set by dyna bolts. The slab is 150mm and 25MPA.
The inspector is going there today to look at the footings (then the slab company are DOING THERE STUFF). All is under control.
STIFFY
Old 10-05-2009, 07:13 PM
LoBelly's Avatar
Originally Posted by stiffy View Post
Boxhead,
STIFFY
Can I book a berth?
LoBelly
Old 10-05-2009, 07:09 PM
boxhead's Avatar
Glad to hear that was organised, would hate to see you try to drill holes for dynabolts only to drill through the slab
Cruising in 5th
Old 10-05-2009, 11:23 PM
stephen low's Avatar
Looks big enough to be a new home for cobra construction.
Starting into a new employment field Mr Stiffness??
slowy
Old 10-06-2009, 01:14 AM
Default Brighton Rent
Lobelly,
Can I book a berth?
Do you know how much rent is in Brighton???
Slowly,
With these hands, I dont think so TIM.....
No its just a garage, the house at the front is for washing and eating, well a few other things.
STIFFY
Old 10-06-2009, 01:42 AM
Ok just the Tool man then!
slowy
Old 10-12-2009, 05:24 PM
Default Progress Finally
Guy's
The men have returned to box up and reinforce the slab.
By late today it will be ready for the slab
So if the rain holds off it will be done tomorrow, BLOODY FANTASTIC
STIFFY
Old 10-12-2009, 07:13 PM
And if you want some extra special attention to quality, don't forget those green inducement packages too!!
The standard trades rate of pay - and now it seems Bathurst has made parity on this issue too!!
slowy
Old 10-12-2009, 07:35 PM
PCC's Avatar
PCC PCC is offline
Stiff,
Its form up the slab
Looking good - hope the rain stays away.
Switch to 40MPA and you'll be right - just may need an extra labourer or two
PCC (Peter Craig)
Keep the sun shining
Old 10-12-2009, 11:27 PM
Default 25mpa
PCC,
It is 25MPA X 150MM thick,
The 2 poster is in the middle of one of the footings therefore it will be in
500mm of concrete...... SAFE.....
STIFFY
Old 10-12-2009, 11:44 PM
PCC's Avatar
PCC PCC is offline
6" is fine - 2 layers of mesh?
PCC (Peter Craig)
Old 10-13-2009, 01:10 AM
Default I prefer 8"
PCC,
One layer of F92 plus the stuff in the footings.
You seem to know a bit about concrete, are you in the game??
STIFFY
