  #61 (permalink)
Old 09-20-2011, 02:10 AM
sambo's Avatar
Thanks Kevin. Mine just arrived from Summit and I hope to fit them on the weekend.
  #62 (permalink)
Old 09-20-2011, 02:26 AM
Merv and Sharon's Avatar
I am sure you will be pleased Paul. I ordered my rears (DD 501s) today. I was going to get the 12" springs but Craig and Muzza advised that the 10" was the go with a small machined spacer at the top of the shock. Otherwise the lower adjustment collars can foul with the tie rod end.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #63 (permalink)
Old 10-16-2011, 08:13 PM
Default Keeper springs
Does anyone know where these keeper springs/packer springs are available in Australia?
Originally Posted by Tenrocca View Post
I have QA1'a which I bought from a mob called Chassis warehouse (proma stars, bearing not bush, single adjustable). Im sure they came in around the $850 landed a couple of years ago - not sure what the dollar was but wasnt quite as good as now. They sell on ebay as well. I have nothing to compare to but I think they do a decent job and appear to be well made.
If you search this forum (the US side) I have read few stories of issues with the Aldan shocks leaking.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #64 (permalink)
Old 10-16-2011, 08:40 PM
boxhead's Avatar
I have the same setup, mine came from kings springs
Cruising in 5th
  #65 (permalink)
Old 10-16-2011, 08:52 PM
sambo's Avatar
Merv, did you get those spigots machined up with those "collars" (below) or can you buy them to suit? I've been looking to redo mine as they were hand cut from stainless tube and they're a bit rough.
  #66 (permalink)
Old 10-16-2011, 09:40 PM
Paul those spigots are part of the QA shocks. They are extremely hard! Thanks Dave I will call king springs.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #67 (permalink)
Old 10-16-2011, 10:02 PM
Dave those are the tender springs from Kings? Where they 70 x 65 @ 70lb? Can't get on to them yet but GSA Wholesale can get them for $80.00 each. Seems steep, given that the mainsprings (QA1) only cost $37.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #68 (permalink)
Old 10-16-2011, 11:51 PM
boxhead's Avatar
I dont have the original reciepts anymore, but I ordered main springs, spring helpers, alloy spacer cup, and Spax shocks from Kings back in about 2004, cost all up was $1k.
I have now fitted AVO shocks, and had to machine the inside of the alloy spacers out an extra 1.5mm to allow them to slide over that shock housing.
Cruising in 5th
  #69 (permalink)
Old 10-17-2011, 03:53 AM
I found an agent on the Sunshine Coast and they can get them from Kings. They are not cheap - more than double the price of the normal spring.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #70 (permalink)
Old 10-17-2011, 04:24 AM
Tenrocca's Avatar
Merv - sent you a PM, but I seem to remember the keeper springs being more costly than the main when I got them too. Maybe they are a special item - to stay compressed for 99.999999999999999999% of their life and still "spring" - might mean they are a bit of black magic?
  #71 (permalink)
Old 10-17-2011, 02:13 PM
sambo's Avatar
Merv I think you've placed washers on either side. That's what I took as being spigots - correct me if I'm wrong?
  #72 (permalink)
Old 10-17-2011, 02:48 PM
Yes Paul. There are some hi tensile washers either side of the spiggots. The shaft is 1/2 inch, not 12 mm.
Many thanks for your help Andrew. I have sent PM back. Hopefully the parts will be here today.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #73 (permalink)
Old 10-17-2011, 04:27 PM
sambo's Avatar
Edit - double post
  #74 (permalink)
Old 10-17-2011, 07:18 PM
Paul - the spigots are the shafts either side of the teflon bearing. The washers are just there for spacing.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
