Old 11-25-2009, 05:58 AM
LoBelly's Avatar
Default String Align Windscreen
My windscreen is cracked and since VicRoads insist that I need a windscreen I thought I'd try to minimise the chances of it instantly cracking again.
I did a quick search and couldn't find much on string aligning your cobra windscreen.
rather than type a couple of thousand words...
It's a handy technique courtesy of my little brother that I had not heard of.
the idea is that the string should cross in the centre and just touch.
LoBelly
Old 11-25-2009, 03:32 PM
sambo's Avatar
Nice tip LoBelly, thanks!
Old 11-25-2009, 03:43 PM
stephen low's Avatar
Originally installed my windscreen and support brackets as one piece.
Hadn't any problems in the short stint of driving I did in the car, but curious if anyone can suggest if I have created a potential stress problem or overcome it too.
slowy
Old 11-25-2009, 04:07 PM
LoBelly's Avatar
Its easy to check Stephen:
- just undo the screws
- remove the windscreen
- check the alignment
It turns out that the under dash roll bar of my RMC was narrower than the 'legs' of the windscreen - which I would imagine created a stress issue
however the crack appeared after we towed the on a trailer with the car facing backward (final straw?)
LoBelly
Old 11-25-2009, 04:18 PM
Ditto
Old 11-25-2009, 04:25 PM
BMK's Avatar
BMK BMK is offline
Good tip mate. Just watch tightening the bracket in the centre of the windscreen for the mirror. I have seen it crack a screen.
I did not use it on my Cobra for that reason.....
Mmmmm Vicccee roads..
Bernie Knight
Old 11-25-2009, 06:15 PM
When I installed my screen I found two issues:
1st the width of the screen to the bar it sits on, if it's too narrow or wide it will stress the screen.
2ndly the angle of the support/bracket on the bar was not on the same angle as the screen so I had to bend it to the same angle. I found this out by another rcm builder clamping his screen to the bar and my the next morning there was a CRACK right down the middle of the screen which made us then check the angle of the screen uprights to the bar bracket. After I did those two things I placed the scrren in and let it find it's own centre. Hasn't cracked yet in 10,000km
Old 11-26-2009, 02:52 AM
BJ's Snake's Avatar
Wouldn't be torque twist on the chassis breaking the screen mate would it!
BJ
289 FIA Cobras RULE!
