Old 12-05-2009, 01:57 PM
schipps's Avatar
Default Harrison seat belts
Calling all Harrison owners,
This will be one of those dumb questions BUT I will still ask it.
Did you fit the inertia reel in the spot shown in the attached photo???
Or have I missed something???
It's just that the inertia reel hits the back of the seat and I can't put the seat in the correct position, all the way back. It misses by about an inch and a half.
thanks
Mick
Schipps
Old 12-05-2009, 02:08 PM
Yes one of those silly things that does not work right
So you can chop a hole out the piece of steel plate (same size as the inertia reel) which will now allow you to mount it hard on the tab welded on the frame.You will have to cover the hole with a steel box to stop water getting into cabin area.
Or you remount the whole reel in the boot area as some people have done.
Bruce
Old 12-05-2009, 02:12 PM
schipps's Avatar
Default Inertia Reels
Bruce,
thanks Bruce. Will cut that fibreglass out and do as you suggest
regards
Mick
Schipps
Old 12-05-2009, 02:46 PM
07cob's Avatar
Default Same same
Mick
I did exactly as Bruce suggested - cut out the 'glass and then mounted the reel in reverse, using the same tab. I then glassed a box around the back of the belt. You will just need to be careful of the handbrake assembly - I ended up having to change some of that as well.
A couple of photos should tell the story.
Geof
Old 12-05-2009, 02:55 PM
Merv and Sharon's Avatar
I had no problems with the seats fouling the reel, Mick but I did have the extended body.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 12-05-2009, 03:10 PM
schipps's Avatar
Default Belts
Geof ,
Thanks for the pics and advice. My next step was going to be to cut out the glass etc...
Merv,
thanks also
Just wanted to make sure I wasn't missing something.
Thanks guys
regards
Mick
Schipps
Old 12-06-2009, 04:33 PM
stephen low's Avatar
Mick
Another of those common cobra problems I suspect. I too lost room to my seats with the reels in the cabin plus the ugly look this arrangement makes.
In the picture attached you can see a T arrangement between the rollbars as the modification to my car. Originally just a solid upright with belt attachment points as standard in the G Force and RMC's.
Now the top horizontal of the T provides an attachement point for the inner roll bar hoops and underneath is the rollover point for the belt as it will come into the cockpit. The vertical plates below the T are where the inertia reels will be attached.
Have you the potential to do a mod like this in the Harrison?
Marty Govitt of Kenmer Engineering thought this very smart piece of work up and I am very pleased as it allows me to run twin hoops and the reels in the boot and frees up cockpit space. The belts appearing out of the rear cabin wall is a much nicer look if you can do it.
Good luck!
slowy
Old 12-06-2009, 08:41 PM
schipps's Avatar
Originally Posted by stephen low View Post
Mick
Good luck!
Slowy,
found the photo in your gallery. Not sure I could do that in the Harrison but in my pic you see the step away directly below the inner hoop, I did think of mounting it there. Would only have to weld a bracket in the boot to attach it to...
Will let you know what I decide
thanks again
Mick
Schipps
Old 12-06-2009, 08:49 PM
Mick
Forgot I had the close up picture of the new Christmas tree in the gallery.
Anyway yes you have to make suit the build, so let us all see what ingenius idea you end up with.
slowy
Old 12-07-2009, 02:41 AM
07cob's Avatar
Default New Belts
Mick
If you do mount the reels up high, just be aware that you will either need new belt assemblies or you will need to get the ones you have shortened, as the reel won't retract all the necessary belt.
Geof
Old 12-07-2009, 02:43 AM
Bruce mentioned the option of mounting the inertia mechanism in the boot on the shelf, that is the way I overcame the problem.
Old 12-07-2009, 03:46 AM
Mando's Avatar
Pecal,
if thats a third brake light light mounted on the body in the last picture, could you let me know what type it is and could you post a few more snaps please?
Regards.
Mando
Old 12-07-2009, 02:12 PM
Hi Mando
The light is a Hella - Part No 5242. You can get them from Bursons for about $90.
Peter
Old 12-07-2009, 02:34 PM
I've the same one Mando and with stripes they tend to blend into the paint sheme a fair bit.
It's one of those safety items I do like, to try and keep the nuff nuffs out of your boot.
Particularly as I don't think the normal brake lights using a Lucas version are either particularly effective nor looked at by following traffic for these cars.
slowy
Old 12-07-2009, 04:31 PM
Stephen, what are those heads on your motor and which plenum is that?
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 12-07-2009, 04:59 PM
Merv
The plennum is the standard 5L top and this is an AU motor but the plennum now looks like this.
And the heads are Edelbrock RPM if I remember rightly. The heads are my first step towards a mild 5L build.
I'm copying a recipe on another car developing about 230rwkw and capable of revving to about 7-8000 rpm I believe, as also built up by Don Stafford.
The planned E303 cam can't be managed by my standard Ford computer and I want to drop on an injected Victor Junior manifold later to achieve the more original look.
As they say these cars remain work in progress and I will enjoy making these changes once I get back on the road.
slowy
Old 12-07-2009, 06:56 PM
I like PECALS solution. Nice and neat. I would have done that but ran out of time.
Does the horizontal position have any effect on the inertis part of the reel.
Bruce
Old 12-07-2009, 07:53 PM
Mando's Avatar
Thanks guys, I reckon that's the one I'll go for.
Regards.
Mando
