02-02-2010, 01:42 PM
Vic
Zedn are those state (NSW) rules? I thought in Vic that for noise you just get some sort of $x00 fine and get a canary slapped on your windscreen, but that is all ????
The Harley point is excellent and one I have never understood, why ARE they allowed to be SO loud?
02-03-2010, 02:18 AM
NSW
Originally Posted by Zedn
He said the major part of the fine was for emmissions. But i think that what you have posted is using a car to make noise rather than modifying a car exhaust.
He said that it was a mobile set up on the side of the road. He thought they were signalling him for a breath test, but when he pulled over it was the EPA and RTA.
The fine seemed a little excessive to me, but i dont think he was lying. I am seeing him again tomorrow so i will ask what the name of the offences were.
Apparently the EPA guy that did the sniff test told him that he can tell he has modified the motor but is not going to go that far into it. He had no cats on the car so that is probably the main culpret combined with the ecu tweek.
Point taken.. the RTA is ridiculously bureaucratic and top heavy These cars are ICV's therefore they meet the design standard by the manufacturer (you) and the Australian design rules...So with a production car the rules are straight forward...with an ICV you must carry an abbreviated engineers report and produce this when required. If the EPA bloke could tell the car was modified it must have been pretty well obvious. I don't intend to 'call unnecessary attention' to my vehicle so this is why I'm asking advice for the exhaust noise and it's remedies.
02-03-2010, 03:28 AM
NSW
This is NSW legislation.
However it says on the DECC (what the epa is now called) web site much lower values. I have a feeling that the high values may be what you get if prosecuted in court (contest the fine) and the on the spot fines (if you choose to accept them) may be less.
I will have a chat to a colleage of mine that i work with tomorrow. He previously worked for a local council issuing environmental fines so has a pretty good understanding of the legislation.
Rob i agree with you about ICV's not being standard production cars and hence they may not know, but keep in mind the compliance plate on the vehicle shows the year and they will then know what ADR to check against. The guy that got the fine said they didnt really know anything about cars, just knew he had other mods from the readings. Probably didnt want to go into it because he didnt know how
I just posted this info to share with everyone. Will i still be running live side pipes? Hell yes!!  But like you i will be trying to make them semi quiet and use cats.
gjkrv8, i dont know about the bike. Those things are super loud, not just Harleys but all bikes with aftermarket exhausts. We have a group that ride past our house late at night on most nights and i always get woken up they are so loud. Im sure they get their share of fines. The thing that i find rediculous is the ones that sit there reving them every five seconds when at lights or riding slowly. Thats just a wank!
02-03-2010, 04:24 AM
Tn.
Cobra Make, Engine: Everet Morrison, Volvo powered. Classic Roadster 302 HO powered
A place I worked at installed a 6" steam jet to produce vacuumed. We received noise complaints from folks 2 miles away. Our plant engineer had us build a muffler for it.
The muffler was nothing more than a section of 12" pipe with a roll of chicken wire fencing inside it. The center of the muffler was totally open because he wanted no back pressure to hurt the effienceny of the steam jet. The muffler was very quiet and after 6 years of operation it was still working. I think you could do the same with a side pipe. If the tips were tacked in place you could experiment to get the sound level you want very easily and inexpensive to try.
02-04-2010, 12:24 AM
NSW
That's what I like about this site...all sorts of ideas and information.. Re the bikes. those dills just get fined and either fit another pipe to pass the test then refit the noisy pipe or... don't pay the fine and spend a week in jail...no problem !
Zedn, my car is registered pre uber emissions rules 2002 and I'm still building it !
02-04-2010, 03:22 PM
NT
The Harley exhaust (and lack of shielding) is why I was approved with just shielding over the cabin entry exit area on my car with the MVR.
They where happy with mine as in there own words "The Harleys have less shielding"
Cruising in 5th
02-04-2010, 08:24 PM
ACT
My engineer flagged shielding as a potential issue as the intent is that you are not to exose anyone to the possibilty of burns. I didn't want a hassle at inspection so I made a full lenght shield from perforated electrical cable tray covering the muffler and collector. Was effective and cheap.
Rob, if you go live pipes, you want to make sure the are well shielded, don't want to burn the bride or you'll never live it down, and reasonably well muffled. You get home pretty beat up after a day out in the sun and buffeting wind with a constant, although sweet, roar in your ear all day.
SLIPRY
02-05-2010, 01:46 AM
NSW
Thanks for the advice SLIPRY.....once the 'muffling' is sorted the heat shields won't be a problem at all.
Smithy
02-06-2010, 04:11 AM
NSW
All of this is becoming too much I think I will stick with my original system...it's there and the dummy sidepipes are fitted. They look pretty good and the noise is approved. I've got too many other things to finish before the car is on the road.
02-06-2010, 05:05 PM
NSW
That's what I call thinking on your feet Rob.
Baz
02-06-2010, 11:53 PM
I agree Rob. My son is an acoustic engineer working for various State enviro projects. The people who check do the right thing. The ones who get fined, make a temporary adjustment and then often revert to their original faults. Fines mean little to them unless that are major ones.
Merv
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-07-2010, 01:00 AM
NSW
Now that I have decided to stick with my original system. I will think about making it better...the mufflers suffered serious damage when the blue slip inspector tried to drive the car onto an old style hoist/ramp and put big grooves in the bottom of the mufflers. In my search for muffling ideas I've seen low profile 'oval' pipe and inline muffling systems that negate the need for bulky mufflers. Once the car is on the road and all the other issues are sorted I will look into making a more 'streamlined low profile' system. i think I saw on one of the "Rides" programs where the whole exhaust system was made of "flat" oval pipe and the mufflers were inside that pipe.....nice and neat !
02-07-2010, 08:11 PM
NSW
Rob,
Here are some pics of my under car exhaust system which passed RTA emmisions at first attempt. Notice the two small 'Cats'.
Hope this helps.
Baz
02-08-2010, 02:12 AM
NSW
G'Day Baz, What's the muffler your using ? looks pretty neat. (brand and pipe size )
02-08-2010, 03:38 PM
NSW
Rob,
It's made by Kirrawee Mufflers, the same mob who suppplied the cats. They also fitted the entire system. If you contact them on 9542-4111 and mention my Cobra's under-car exhaust system, I'm sure they will supply you with all the info that you require.
Baz
