02-11-2010, 04:20 PM
NT
Front number plate mounting.
Well I find myself with a happy problem.
How can I mount the front number plate without it covering the oil cooler intake?
At the moment I have it cable tied infront of the oil cooler hole.
Show me some pictures of how you have mounted yours, any ideas for brackets off the quickjack points (but then not obstruct the indicator)
Or do most people keep it behind the seat and say "Honestly officer, it just fell off".
Cruising in 5th
02-11-2010, 04:30 PM
VIC
No front number plate req'd locallyif there is no place to mount it
You might want to check this for NT
LoBelly
02-11-2010, 06:41 PM
VIC
LoBelly
Hey LoBelly, Can you let me know where in VicRoads this is stated, as I made a backet for mine and dont like having to have one.
Rgds
Gregg
02-11-2010, 09:14 PM
VIC
Rgds
Gregg
Hello Gregg,
I'm not really sure but off the top of my head I think its the Road Safety (Vehicles) Regulations 1999(?) part 2 regulation 222 (3) a & b
noting that the ability not to fit the plate is a consequence of the car design and the lack of a space to fit it. all sorts of arguements could be entertained on this point but...
... the acid test (for me) was my visit to the Traffic Management Group where the lack of a front number plate was not amongst the [extensive] list of improvements required - didn't even rate a mention
LoBelly
02-11-2010, 09:38 PM
VIC
Hello Gregg,
LoBelly
Hmmmm... Thanks for the info. Maybe I'll leave well enough alone if it is not too clearly defined.
Rgds
Gregg
02-11-2010, 05:47 PM
NT
Thanks for the tip LoBelly, I will check up on that.
Cruising in 5th
02-11-2010, 07:09 PM
CO
02-11-2010, 07:54 PM
NT
Thanks Bob, exactly the sort of thing I was thinking.
If I need one then this is what I will get.
Cruising in 5th
02-11-2010, 11:04 PM
NT
Cobra Make, Engine: King Cobra, QLD - 347 windsor
BOXHEAD
Motor vehicles Act NT Legislation.
You will need to apply for an exemption under section 16 sub - section 3 for an exemption, on the grounds that it will restrict airflow etc and that the inclusion of a suitable fitting would compromise safety of other persons should you hit a pedestrian.
Thats how I would do it.....
16 Affixing of number plates
(1) Subject to subsection (3), the owner of a registered motor vehicle, other than a registered motor cycle or trailer, shall, upon the issue to him of 2 number plates of a design, type and material determined by instrument by the Registrar for such a motor vehicle, cause them to be affixed, one to the front and the other to the rear of the motor vehicle, in accordance with the requirements of Schedule 4.
(2) Subject to subsection (3), the owner of a registered motor cycle or trailer shall, upon the issue to him of a number plate of a design, type and material determined by instrument by the Registrar, cause it to be securely affixed to the rear of the motor cycle or trailer.
(3) The Registrar may, in his discretion, upon such conditions as he deems fit, by instrument exempt a person from the requirements of subsection (1) or (2).
Hogster
02-11-2010, 11:45 PM
NT
Thanks for that Hogster, I will have to look into sending in a request submission.
Honestly not too fussed as I dont mind the number plate off to the side like in the linked kit.
Cruising in 5th
02-12-2010, 12:08 AM
NSW
Dave,
I take it that your not planning on running with a chromed oval around the nose hole? Would that be right? I have slim line plates which have been held at the RTA for over 2 years. Eventually, when I get them, I plan on mounting the front one to the top of the chromed oval around the nose by using small rubber inserted hose clamps which has the number plate secured to the front of the clamp then wrapped and fastened around the chromed surround. It works well for slim line plates. Unfortunately, a front number plate is required in NSW.
Baz
02-12-2010, 02:31 AM
NSW
In happy NSW there is a $308.00 fine and 3 points off the licence for a partially obscured number plate.......Zieg Heil
02-12-2010, 05:28 AM
NT
Yeah Baz, no chrome on mine, going for the race car look.
Cruising in 5th
02-12-2010, 03:50 PM
Remember when the E Type Jaguar came out in the early 60s? This same problem came up in the UK and was solved by allowing a decal of the registration details to be mounted directly above the radiator opening.
It probably didn't do much for the paint, but if the label/decal was to be a permanent fixture, it didn't matter.
It was a cheap easy fix. Nearly fifty years later, I wonder if we've caught up down here in Oz? The decal wouldn't photograph too well for the flash-for-cash cameras but it could be argued that at least it's [i]something[i] to provide frontal vehicle identification.
Might be worth a try if your application not to have a front plate fitted is knocked back.
02-13-2010, 03:16 AM
NSW
There are some local cobra owners that have that decal deal on the top of the radiator cowl / nose and as far as I know they haven't been "bothered"yet.
02-13-2010, 03:29 AM
I don't think that this would particularly disturb airflow for an oil cooler.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-13-2010, 07:44 AM
VIC
Number plate mount
My plate is tek screwed on the bumper as shown in the pic. Doesn't appear to inhibit air flow in any way.
Bryan
VK3KDN
02-14-2010, 08:10 AM
Gotten 3 warnings for not having a front plate. I still don't like it but gotta have it. This plate holder is available from Branda, if I remember correctly. It goes behind the indicator light, 3 holes pre-drilled. Required a little bit of filing...
[IMG]  [/IMG]
Ray
New York
SPF#1052 11mpg
CAV GT40 MONO29 9mpg
'01 MB CL600 V12 18mpg
'08 Volvo S80 18mpg
02-14-2010, 09:30 PM
I suppose we do have some leeway in Qld, in that a slimline personalised plate is available.
Normal size is 375 mm X 134 mm, with the slimline version being the same width but only 100 mm high. A small concession, but it all helps!
The personalised plates are available in just about any colour combination you can imagine with a variety of backgrounds too.
www.ppq.com.au
02-14-2010, 11:23 PM
NSW
[quote=JCoop;1028686]Gotten 3 warnings for not having a front plate. I still don't like it but gotta have it. This plate holder is available from Branda, if I remember correctly. It goes behind the indicator light, 3 holes pre-drilled. Required a little bit of filing...
