Old 02-27-2010, 03:33 PM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by Philm View Post
Hey David,
Have you ooked at the radiator hoses, maybe the feed from the rad to the pump is sucking closed,starving the pump with water at speed.
Phil
That's also a good possibilty seeing that he already replaced the radiator( didn't see that before I last posted). It's not uncommon for the spring that is in many to fall out or removed when radiator or other work involving the hoses is done.
WDZ
Rate This Thread:
