questions
- » Blogs
- » Image Gallery
million posts!
| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
07-02-2010, 03:12 AM
Qld
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
charcoal canister 1976
Hi crowd,
as a 10 yo (then) I remember the big day the new tough emmission rules came in and we all had to have charcoal canisters and all that pollution crap hampering our cars perfomance.
But I have never wondered until now if there is a "RULE" that states an actual date/ age or size requirement for a charcoal canister on a new build.
My Datsun Bluebird and Ford meteor candiates would fit well with my plan shape wise.
Extra info, L76 with evap solenoid, circa 95 litre alloy drop tank, vent to canister planned as hose and tube combo before a triple coil of hardtube terminating at the higher end of the filler neck. (The triple coil was a speedway rule for rollovers we had to comply with. Worked well too.)
Any past experiences, especially bad ones (testing/ rego hassles) I can learn from are welcome.
Thanks
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
Advertising
07-02-2010, 03:55 AM
Qld
I should have googled more before I asked.
37/01 Use of remanufactured charcoal canisters
Q76. Can a remanufactured charcoal canister be fitted in lieu of a new canister to meet ADR 37/.. Requirements?
No. Note 3 of ADR 37 Emission Controls For Light Vehicles requires a new canister (to sample vehicle specification) to be fitted.
OK, so if re-man wont do then surely old ones wont ??? Is there a volumetric spec for canister size?
07-02-2010, 04:44 AM
VIC
What has your engineer specified?
07-02-2010, 09:45 PM
As far as I'm aware (according to my car manufacturer) you can use whatever you like.
I started with a Commodore cannister from the wrecker and found it a bit big so then went and blew another ten bucks for a small one out of a jap car, bracket included. Burglars
Vac hose from manifold draws vapour from both BA Falcon fuel pump and tank vent. It had occured to me if the tank was full enough whether the fuel may be drawn into the cannister. I haven't filled it yet.....I guess we'll see.
As Sambo notes, it's up to your engineer to pass it.
07-02-2010, 10:27 PM
NT
I would check with your engineer, but mine did not have an issue with the second hand Telstar one I fitted.
Cruising in 5th
07-03-2010, 03:22 AM
QLD
I got a new Commodore one. They are cheap anyway.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-03-2010, 02:14 PM
Qld
Thanks for the input.
Out of curiousity what size is the commodore one Merv and approximate cost?
Technically the canister is a consumable item but NEVER in 30 yrs on spanners have I changed one as part of scheduled servicing.
BTW, if anyone should ever decide to use an EF canister make sure the one way valve is fitted the right way, our old wagon used to fill with fumes to a point that was just downright scary due to it being fitted wrong from factory. Not an isolated incident on EFs
07-03-2010, 03:31 PM
QLD
I think it is about 10cm by 15cm. Now that I check, the cost was $130. I was 'told' to get that by Harrisons, so I did. Part number GM=17091157.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-05-2010, 01:19 AM
Qld
Thanks Merv for the part number info.
A visit to our local holden dealer shows that as a VL> canister and it it currently around $180. We did a bit of a compaison after that and found VS/VR are round and still pricey, VE is a layed down oblong looking shape but the winner on the day is probably the VZ V8 canister at $77 plus the bracket. The VZ V8 canister is conveniently stand up oblong in shape and also matches my engine model being to suit L76.
To avoid any hassles later on I think I'll get the VZ one and know it's all shiny, new and conformist. It will fit nicely tucked away in the back too.
Thanks for all the input guys.
