07-13-2010, 10:22 PM
5.0 windsor dipstick
Fellas
My engine was supplied with standard oilpan and no dipstick, so I've purchased one aftermarket to suit a 5.0 Windsor
However, when adding 5 litres of oil, which seems to be universally recommended by various US forums, there's no sign of it on the dipper.
I've got good pressure on the gauge and no warning light indicating it's low.
What do ya reccon?
07-14-2010, 01:01 AM
VIC
A lot of those after market dipsticks rely on you filling your motor with the volume of oil you want and then either cutting the dip stick to length or shortening the dipstick tube to suit.
Mike Murphy
Melbourne Australia
07-14-2010, 05:25 AM
Greg,
I reckon that if it is a standard Windsor (check the Ford Aust specs as I think yours is one of theirs) then it is 5 litres normally. Shortening the dipstick tube might be the go, as Mike suggests. I would check the Ford Aust service specs, however (or visit the wrecker?).
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-14-2010, 08:52 AM
CO
There are two dipsticks. The short one goes through the front cover, passenger side. The long one goes through the block, passenger side. Some pans also have a fitting for the dipstick, and they generally use the short one.
Since you've already purchased and installed the short one, you might be able to get by with shortening the tube. But sometimes that moves the handle down so low you can't easily reach it..
07-14-2010, 09:46 AM
Cobra Make, Engine: Factory Five MkII with a Ford Racing 302 Crate engine
If you bought a crate engine as i did years ago the dipstick is on the opposite side as we are used to. I was told by Ford that this is because the crate 302 has an oil pan from an Austrailian Falcon. I got the dipstick for the Falcon and it works perfectly.
07-14-2010, 05:50 PM
Thanks fellas
I'm pretty sure my engine is a US jobby, Merv so I think 5 litres is about right.
Now you US friends, things get very confusing when you refer to passenger side......are you converting to Aussie first :-) only one hole for the dipstick though.
Looks like i'll get out the hacksaw........
07-14-2010, 10:22 PM
I think so Greg and they are a bit sensitive to overfilling ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
07-15-2010, 08:56 PM
Try putting the sump plug in.
07-15-2010, 09:17 PM
5 litres???? I wish that was for me.... My thing sucks in 12 litres every change and at $200 for 5 litres of The Royal I choke after every oil change. Which is alot more regularly than you want to even ask! Lol
07-17-2010, 04:07 PM
Matt, you will fly with the elite........looks like a sponsorship deal may be the go!
07-21-2010, 04:06 AM
NSW
Cobra Make, Engine: Homebush fibreglass body and chassis, running stage2 302 cleveland on LPG.
Jeez spooky where in god's name would you put 12 lts?????? what you fillin up your boot or what lol
07-21-2010, 05:58 AM
Very large petersen oil tank res off dry sump! Although I must check the boot just in case!
