Old 01-01-2011, 12:03 AM
Question Pic's of Dashboard
Hi everyone & happy new year to you'all.
Am about to start muckin' about with my dash and would like some pic's of what people have done please. Not sure what I want really, just after some ideas
Rog
Rog 246
Harrison #100
Old 01-01-2011, 12:25 AM
purge98's Avatar
Cobra Make, Engine: DAX Tojeiro SBC
...and a Happy New Year to you.
This dash is the standard fit on UK Dax 427 replicas. Might give you some ideas..
http://www.clubcobra.com/photopost/s...//ppuser/39263
jason
A Dog is not just for Christmas; If sliced thinly enough, it can last until Easter.
Dax TojSBC 377 3550 BOx
Old 01-01-2011, 12:53 AM
boxhead's Avatar
Here is mine. It is wrinkle finish paint on fibreglass.
I set the gauges out so all can be seen around the steering wheel.
The headlight switch is Mk 11V jag.
Cruising in 5th
Old 01-01-2011, 02:16 AM
Merv and Sharon's Avatar
An original Dash:
My dash (aluminium with a vinyl covering)
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-01-2011, 02:29 AM
Mando's Avatar
This is mine.
Regards.
Mando
Old 01-01-2011, 03:13 AM
I collected more than 100 dash layout pics Rog. I also have the original SC 427 and the 289 layout templates.
I wanted something that was associated with an original look. Another US original below. Stewart Warner gauges and speedo and tacho behind the wheel - perhaps not the best location for visibility.
It all depends on whether you want an 'old school' look or a modern layout. In some states they may have a thing about the types of switches as well.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-01-2011, 06:59 AM
Cobra Make, Engine: RMC, Jag chassis, Holden HSV 5ltr engine, 5 speed Getrag box.
Default Dashboard layout.
Pics of my dashboard layout are attached.
All electronic and connected to the car wiring loom by 6 plugs.
Old 01-01-2011, 01:21 PM
An original 427 layout and a recent Kirkham. Generally, however, most current builders keep the tacho' and speedo away from behind the steering wheel. The last shot shows a variety of layouts.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-01-2011, 02:33 PM
steeler's Avatar
Cobra Make, Engine: G Force, Motorsport Boss 302 (LPG).
Default Dash Layout.
Mine is OK, but Tach and speedo should be changed over (Engineers direction this way).
Old 01-01-2011, 04:34 PM
Wazza's Avatar
Here's mine........
and one of my "Old" Cobra....
Warren
Old 01-01-2011, 04:40 PM
stephen low's Avatar
Rog
A couple of pics from my gallery showing my layout.
Will be adding two further rotary switches beneath the two near the wheel for extra heater controls. Will have backing plates made with engraved signage for the swith uses and will get the knobs black annodised to match the layout look.
The courtesy light and pull switch below I got off ebay from an MGB if I recall correctly. This works well at night and comes on with door opening or pull of the switch for any night map reading I may need to do.
Large space below will also house a stereo unit when I'm closer to finishing the car.
Would echo the sentiment about being able to see the gauges and with modern steering wheels anything tucked to the right of the steering column tends to get lost or relatively unsighted.
Good luck with your choice.
slowy
Old 01-01-2011, 04:44 PM
martrogers's Avatar
Cobra Make, Engine: Homebush fibreglass
All mod cons...
If in doubt mumble.
Old 01-01-2011, 05:20 PM
BJ's Snake's Avatar
Default Dash Pic
Mine is just fibreglassed MDF and painted same colour as stripe. The good old K.I.S.S. way.
289 FIA Cobras RULE!
Old 01-01-2011, 08:10 PM
gjkrv8's Avatar
Mine is fairly simple as well.
Didnt go for the glove box as have great side pockets in doors which I find more convenient.
Anything I need to keep secure goes in the boot.
fibreglass panel with foam padding and leather covering.
Old 01-01-2011, 11:42 PM
Andrew429's Avatar
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Default Dash Pics
I went for an old school look based on the S/C layout, aluminium panel covered in leather, modern lights, old school gauges.
Andrew
Old 01-02-2011, 12:02 AM
Andrew429's Avatar
Default Dash Pic
One more
Andrew
Old 01-02-2011, 01:19 AM
and some have less connection with the original Cobras, but are what the builder wanted as a modern statement:
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 01-02-2011, 04:46 AM
Hey fella's that brilliant, just what I've been looking for Thanks
Rog
Rog 246
Harrison #100
Old 01-02-2011, 04:38 PM
1985 CCX's Avatar
My old CCX which is now in Australia...... Miss it too.....
Old 01-03-2011, 01:19 AM
"Q"'s Avatar
"Q" "Q" is offline
Cobra Make, Engine: 383 Stroked and Blown Chevy powered Cobra
Default More dash pics
Another "modern" approach.
Similar links that might also give you some more ideas:
http://www.clubcobra.com/forums/show...98#post1067598
Dashboard ideas
