| 29 |
03-27-2011, 08:27 AM
WA
Cobra Make, Engine: FFR Mk4 Roadster, LS3, TR6060, 8 3/4"
Seat Tracks - a quick question
So seat tracks - do I have to have them?
Because I am stuck for room I was planning on making my seat fixed and sized to suit me. Shorter people, if I let them drive, could be accomodated with a cushion insert behind their back.
I had a look in the ADR's and do not see anywhere where it says seats must be adjustable. However, word on the (WA) street is it is required.
Can anyone comment on this?
Tim
FFR Mk4 Roadster
HSV Clubsport R8
03-27-2011, 09:55 AM
Cobra Make, Engine: CSX 7030 HP 289
You don't need no stinkin' seat tracks. I'm 6'2" and didn't want to look over the windscreen. So, I had to go to a thin racing shell with NO tracks; much happier.
You say you might be required to have them? I say: Question Authority! Cheers, Tom
Take back the country in 2012. Pass it on.
03-27-2011, 05:09 PM
NT
I am not 100% sure on this, I would ask your engineer.
I "thought" they where required, so built some in on my car, but the engineer never checked it.
Cruising in 5th
03-27-2011, 05:28 PM
Don't have them in my car or several past Cobras as it puts you lower in the car and much more room. In my case knowone is going to drive my cobra anyway so they are set for me which is all the way back and front tilted up a bit. Works great.
CAV GT40
03-27-2011, 06:02 PM
VIC
I was told that in Victoria (Australia, for the US posters here) we need seat tracks, the idea being that some adjustment is necessary to allow drivers of different heights to reach the pedals and drive the car safely. I haven't verified this 100% but it sounds pretty sensible to me, at least from an engineering perspective.
03-27-2011, 06:17 PM
I remember some time back QT also required seat track/adjusters and that each track required a positive locking device. ie. Not locking on one slide only.
Dunno if there has been a change though.
03-27-2011, 07:59 PM
WA
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi Jethrow,
I'm pretty sure you will need an adjustable drivers seat (mine was checked) but you can have a fixed position passenger seat.
Andrew
03-27-2011, 08:57 PM
WA
Especially if the guy doing the testing at inspection time is vertically challenged !!!
My understanding is that it is a requirement here in WA.
03-27-2011, 09:05 PM
Here is the Vehicle Standard (Australian Design Rule 3/03 – Seats and Seat Anchorages) 2006.
http://www.comlaw.gov.au/Details/F20...c1171251969380
My cars were registered without an "adjustment sytem" in Qld.
03-27-2011, 09:12 PM
I'm not sure what setup you have with your tracks some have the same hole spacings on the seat as to the floor.....can you take them out after rego???
03-27-2011, 09:18 PM
WA
You can do anything you like after rego, insurance might be a different thing...
03-27-2011, 09:23 PM
Vic
SHhhhhhh....  ....The RTA might be watching!!!..    ..
03-27-2011, 09:53 PM
WA
as long as it's only the RTA and not our DPI !!!!
03-27-2011, 10:36 PM
NSW
Im not sure about WA, but in the lovely state of NSW i wouldnt be doing it because the RTA would wont the brackets tested as the seats would be considered modified and no longer ADR compliant.
03-27-2011, 10:46 PM
WA
Don't forget their big NO stamp, the only one they own...
03-28-2011, 01:23 AM
I was told in QLD that is was not needed and opted for the lower seat height. Engineer was happy with that when I was inspected. Check with your engineer.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
03-28-2011, 03:02 AM
Qld
What's the DPI (Dept. of Primary Industries) going to do apart from check from cattle ticks and weed seeds?
I was told I needed a drivers side slider but I know many others haven;t had to do the same.
To avoid any argument on the day I have sliders.
If the wooden dummy sits well on fixed seats it may be OK.
Probably best you get your engineers opinion as everything seems to be open to interpretation.
Ya get that on big jobs.
03-28-2011, 03:47 AM
WA
Thanks for all the responses guys. I guess I will have to chat with my engineer to be sure. However, the ADR, whilst it states that all adjustment mechanisms must be locking, it does not say the adjustment mechanism has to be there.
Actually, this seems to be a common peculiarity of the ADR's. If you look at ADR11 for sun visors, it states the rules that apply if you have them. But where is the rule that says you have to fit them in the first place?
Originally Posted by WKB
Tim
FFR Mk4 Roadster
HSV Clubsport R8
03-28-2011, 04:52 AM
WA
If I told you it stood for Department of Transport would you believe me?
www.dpi.wa.gov.au just to show I'm not kidding!
It's a legacy of the Department of Planning and Infrastructure who was split into three agencies and run the show when it comes to licensing. But I've heard people have developed nervous ticks after their first ride in a Cobra.
03-28-2011, 10:54 AM
When did our Commander in Chief fit in a trip to Downunder?
Anyway, I go for suggestion to fit the tracks for the inquisition and then remove following the approval. Or do your cars get analyzed on a regular basis? If so, you live in more of a "nanny" state than I do.  Cheers, Tom
Take back the country (USA) in 2012. Pass it on.
