Old 04-24-2011, 01:38 AM
Zedn's Avatar
Default recommended gearbox clearance?
How much clearance is recommended between the gearbox and tunnel? I am running an ls3 with T56. I currently have about 20-25mm on each side, which seams like enough but would hate to start her up and have rattles.
Cheers.
Old 04-24-2011, 01:49 AM
G'Day Liam,
I have urethane engine mounts and about 10 mm between the bell-housing and the chassis on each side. My tremec is pretty close to the tunnel above and I'm having a small problem with the new rubber gear-stick boot...being new and stiff it actually pulls the thing out of gear when I'm in top and just coasting. It's fixable.
Old 04-24-2011, 03:35 AM
Gaz64's Avatar
Most would consider 10mm as acceptable minimum clearance.
If your mounts allow more flex than this, then they aren't up to the task.
20-25mm is plenty.
Gary
Old 04-24-2011, 05:30 AM
jcraigau's Avatar
Cobra Make, Engine: G-Force Mk1, LS1, T56, Jag S3 suspension
If it was knocking at 25mm I'd bolt it in!!!
Old 04-24-2011, 05:38 AM
Tenrocca's Avatar
I concur - more then enough.
Old 04-24-2011, 03:16 PM
Zedn's Avatar
Thanks. I think im just being over cautious
