05-18-2011, 11:32 PM
NSW
Failed Oil Cooler?
Has anyone ever heard of the Oil Cooler located in the front of the body under the "Oval' opening failing? I would be interested in some input here.
I have utilised the Oil Cooler that most builders utilise for the engine, but in my car this Oil Cooler provides cooling for my 6L80E 6 speed Tiptronic Transmission. My concern here is:-
Would my transmission be cranking out more pressure to the Oil Cooler than the Oil Pump on an
LS2 6 litre GM engine which could in fact cause the Oil Cooler to fail?
Baz
05-19-2011, 12:07 AM
VIC
Not sure about the oil pressures involved with an auto transmission but engine oil pressures can be up to 70psi. Combine that with cold sluggish oil and you can blow one apart.
With an engine oil thermostat setup it's good to put a one way check valve in the return line from the cooler. That way the thick cold oil under high pressure cant get pushed back towards the cooler. from the engine while the thermostat is shut.
Mike Murphy
Melbourne Australia
05-19-2011, 01:49 AM
vic
I use an earls cooler up front for the trans cooler on mine too Baz, I have a stall converter fitted to my 4L65e that produces more heat than a standard trans and have had no cooling issues even on track days and 40+C days.
Pressure wise I don't know what they are capable of, yours should be no different to mine.
Powered by Cu
05-19-2011, 02:37 AM
NSW
Thanks Gav,
I'm asking this because last Tuesday, I blew my Oil Cooler to smitherines. Dropped about 4 litres of transmission oil over 100 metres and you should have seen the white smoke from the oil on the exhausts out the back. I thought my dream car was going up in smoke. The new Oil Cooler had only done a little over 1,000 ks and the transmission was running at normal operating temperatures when the Cooler let go. Maybe it was just a lemon of an Oil Cooler. The tow home cost me $200.
That's why I am trying to find out if anyone else has has a similar problem. I was running an 11 row Derale Oil Cooler at the time.
Baz
05-19-2011, 02:43 AM
Qld
Hi Baz
Where did it fail?
Phil
05-19-2011, 03:27 AM
Had an engine oil cooler on a rally car crack once. We redesigned the mounting to provide more compliance and no more dramas. A real low pressure oil light came in handy that night.
Geoff
05-19-2011, 04:27 AM
Most of the time an automatic transmission cooler line will not have the same pressures as elsewhere in the transmission. Many areas of the transmission have very little or no pressure ie: the sump which is where most cooler lines return to. I would say that you had a defective cooler. Earl's has been around a long time. It's not likely a faulty design.
05-19-2011, 02:39 PM
NSW
Originally Posted by Philm
Hi Baz
Where did it fail?
Phil
Still investigating that Phil. Will let you know when we find out.
Baz
05-19-2011, 02:46 PM
vic
You don't have a blockage do you Baz?
What size lines are you using?
Powered by Cu
05-19-2011, 02:47 PM
oil cooler
I have a mocal oil cooler that I am going to fit in either the engine pressure side or the scavenge side of my oil system, and use a Canton thermostat so the cold oil pressure wave at startup goes into the block and not destroy the oil cooler.
A J. Newton
The 1960's rocked!
05-19-2011, 03:49 PM
G'day Baz,
Probably telling you how to suck eggs but these coolers must be mounted top and bottom.
They can blow apart and if the pressure don't get them the vibration eventually will.
05-19-2011, 05:56 PM
NSW
Originally Posted by suthol
G'day Baz,
Thanks Dave, I have mine mounted as you suggest. Possibly just a one off lemon. I will advise the results of the post mortem shortly.
Baz
05-19-2011, 06:18 PM
Qld
prediction
Hey Baz,
If I had to guess, the fittings into the cooler were overtightened and this weakened/ cracked the unit, then a bit of vibration, heat and pressure then the weakness failed.
Phil
05-19-2011, 06:53 PM
NSW
Hey Baz,
Phil
That would possibly be the reason if I tightened the fittings originally, but Neil installed it so I doubt whether that was the reason. The car is at his place now and hope to pull the cooler out this afternoon so we will know the reason soon.
Baz
05-19-2011, 11:04 PM
Transmission Oil coolers are used in many OEM towing applications, go look at a few new vehicles and compare to what you are using and how they are plumbed.
If you are using a conventional oil cooler, be sure to mount it so the body is sandwiched and not located by the bottom or top end plates alone, Earls has in their catalog some examples of how to mount them, vibration will definately shorten their life dramatically.
05-20-2011, 05:32 AM
Q
LS2 6 litre
Baz
Baz, I can't say what your trans has, but my modified Powerglide auto has 240psi line pressure...
Craig
05-20-2011, 03:40 PM
KS
Cobra Make, Engine: jbl
i had an oil cooler on the front shoot craps, started leaking, luckily it was not pressurized oil into the engine but scavenge oil, don't know why, never did find out.
ant, could you explain the cold oil pressure wave? my dry sump would run 230 deg with 12 qts oil and no oil cooler street driving scavenge oil going directly into the tank, with cooler it was about 150 deg. driving around normally, will have to make a shield.
05-20-2011, 05:18 PM
NSW
My 6L80E has the same maximum pressure at 250psi. The Derale Oil Coolers allegedly have been tested to 250 psi so everything should have been "cool".
Baz
05-20-2011, 05:25 PM
vic
That is line pressure Baz, not cooler pressure.
Line pressure is the operational pressure inside the box operating clutches ect.
Powered by Cu
05-20-2011, 10:12 PM
NSW
Copy that Gav. The Derale Oil Cooler is tested to 250 psi. I have researched the 6L80E.com website and there is no mention of pressures leaving the box. Me thinks that the only way I can establish the outgoing pressure from the transmission lines into the cooler would be to temporarily fit a gauge to the inlet side of the transmission line where it enters the cooler and actually measure the pressure this way. Any ideas on this proposal?
I know that there is a **** load of pressure created within the box. The first time I drove it, we failed to remove a yellow plastic plug from around the transmission breather pipe which is located on the upper rear portion of the box. After a few kilometres, the plug blew out with such force, that it dislodged the metal cradle which holds my sound system in place by around 6cms. The air release was similar to a truck dropping its air brakes.
Baz
