268Likes
02-17-2013, 06:46 PM
NT
You will laugh at me, but this stuff works and my engineer had no issue with its use.
Clear Vinyl Tubing | Clark Rubber
Sit is it a bucket of hot water to make it more pliable.
Cruising in 5th
02-18-2013, 12:53 AM
VIC
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
Originally Posted by PeterAllen
Can radiator hose be used as fuel filler hose? I am routing the fuel filler out behind the numberplate and all the donor car bits can be used except the filler hose. Can I just use radiator hose?
Google CAR BUILDER SOLUTIONS in the UK. I have ordered 1m 2in hose, and a joiner. Meant to be super flexible, looks flexi in the photo. Mine is on order, hope to get it in the next week or two!
02-18-2013, 09:06 AM
I think your build is awesome. The lengthening of the chaise will greatly improve the handling. You can come play in my shop any time. Do you have an idea of the weight yet and the front to rear yet?
Bill Emerson
02-18-2013, 02:13 PM
NSW
Thanks for the comments:
Boxhead - The hose only needs to be 200mm long but have a 90 bend, so I think flexible is really the only way to go.
Sevenohms - Motorsport Connectors are here in Sydney so for me it's probably easier to get it from them, thanks anyway.
Bill - I would LOVE to play in your workshop rather than my single car garage but I think the logistics associated might be a wee bit too much! I'll be in CA next year on my way to the Indy 500 so I might drop by for a chat and a Bud. I expect the car to be around 1050kg (2300lbs) and based on other 240z/LSx combinations using the same engine mounts etc, the distribution should be very close to 50/50. The stretched wheelbase might be a later option but for now I just want to get my health back and GET THE BLOODY THING FINISHED.
02-18-2013, 03:28 PM
By all means get healthy and come see me and we will hoist moor than few.
Bill Emerson
02-19-2013, 12:33 AM
NSW
Enzed will have something. They have shops all over Australia. There prices aren't the cheapest but for the small amount it shouldn't be much. I am using stainless tube and bends with a couple of small bit of hose for joiners at tank and filler.
02-21-2013, 02:58 AM
Peter
I tried to get something flexible and ended up at Enzed. They said the only flexible thing that would handle fuel was marine exhaust tube. I got some but it was not flexible enough. Ended up making this up:
Geof
02-21-2013, 09:10 AM
Summit Racing® Stainless Steel Flexible Hoses SUM-390024 Chek this out
Bill Emerson
02-21-2013, 01:03 PM
ACT
Thats listed as radiator hose - not fuel hose
SLIPRY
02-21-2013, 07:07 PM
Try marine / boat / jetski places as they may have fuel hose suitable.
My jetski fuel tank hose had nice length with a 45 and a 90 degree bend. Cant remember the i.d.
edit..... I just had a look on ebay... there are many there so something may be suitable.
02-21-2013, 08:04 PM
vic
Ring 'purple pig' and ask for 'radcoflex' flexible convoluted stainless hose.
I use it for flexible gas lines it comes in 32,40 & 50mm dia. Mine are usually fitted with ends but you should be able to buy it by the meter.
Comes in braided too if you want some bling
I have used it for my filler pipe and has been fine for years now.
Powered by Cu
03-01-2013, 01:40 PM
NSW
One of the best know kits around (stretched wheelbase and V12) is for sale - USA.
Ferrari : Other 2 door coupe in Ferrari | eBay Motors
03-02-2013, 05:17 PM
NSW
Progress – My cardiologist gave me the thumbs-up… well, she raised her index finger and mumbled something – so work has recommenced.
I have placed a 40x40mm tube along the existing sill so that it contacts the base both the 'A' and 'B' pillars
I removed the outer portion of the rear wheel arch and trimmed the guard opening to suit.
I attached the new (wider) sill.
I discover that I couldn't open the door - D'oh. I had to rework the area below the hinges. The area is covered by the front fibreglass guard when all is finished.
I made up new rear tubs.
I made up strips to attach the tubs to the original guards.
I made a new panel for the latch area.
I had a beer and went to bed!
03-02-2013, 06:10 PM
VIC
Great to hear your back in the shed! And excellent progress!
03-03-2013, 04:28 AM
WA
Are you sure it's the shed?
If it is its very cosy with those lovely rugs/runners.
I wish I was working in such a warm environment.
03-03-2013, 05:17 AM
NSW
'A SHED'... luxury. It's only a timber frame with a bit of cladding but it's a shed to me.
I'm worried if Aussie Mike sees this spacious hi-tech facility he might get envious.
03-05-2013, 02:33 AM
NSW
Looking good Peter, keep the updates coming. Its interesting to see it coming together.
Liam
03-07-2013, 05:05 PM
NSW
I kinda feel like you guys (gals) when your kit first arrives.
Hopeful that all the R&D is over and I can commence the final assembly. It's back on the rotisserie so that various new panels can be 'down' welded - not a fan of overhead welding! After that a bit on sealer sprayed on the underside and the interior sprayed, then back onto its wheels to fit and prep the bodywork.
03-07-2013, 05:08 PM
VIC
Looking good Peter. Glad to see you making progress again.
Mike Murphy
Melbourne Australia
03-11-2013, 03:50 PM
NSW
Isn't it great when a big package arrives from the US... and, your wife isn't home!
