Old 08-13-2011, 01:27 AM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
Default Funny thing happened at engineering the other day
Guys,
Car is currently going through engineering and they were doing the brake tests when 'bang'. Upon inspection it was revealed that the axle had split at the diff end in the CV and the long half was turning with the wheel.
Doug got the car to his place and had a look and we found that a bolt holding the diff had torn through the material holding it in place. This in turn allowed the axle to split at the CV due to the extra length it all of a sudden had.
No damage was done to the axle as it was put back together with some new grease after a clean out and inspection. Now working on strengthening up this area with a beefed up plate etc.......
The fun never stops!!!
http://www.clubcobra.com/photopost/u...diff_1_web.jpg
http://www.clubcobra.com/photopost/u...diff_2_web.jpg
Old 08-13-2011, 01:38 AM
Merv and Sharon's Avatar
That must have been exciting. Was that the rubber doughnut, (there are two) at the nose of the diff? If so replace them with solid alloy ones. You have a lot of torque there.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 08-13-2011, 02:36 AM
Cobra Make, Engine: Harrison , 5lt Ford . FF GTM 6LT GMH
Default bang
That is not a Nissan IRS set Merv . Matreial a bit light for the 6L supercharger i think .
Old 08-13-2011, 02:44 AM
Yes, that's what were thinking, and have re-designed something using 6mm steel to take the place of the 1.5ishmm used there.
It may have been pulling it up when it was strapped down to the dyno, as there is no where for the diff to move as suspension is tight and through the tests etc.... it got weak and then decided it had had enough and went bang. No damage was done though, so it will come back rebuilt and stronger etc,...... just like the 6 million dollar man!!!!.
Getting near to it being completed.
Old 08-13-2011, 02:54 AM
Mrs flatchat's Avatar
Red face
Yeah - that wouldn't have happened if you'd used a Ford engine
Old 08-13-2011, 03:11 AM
Funny thing is that the diff is the only Ford part, (and the charcoal canister and steering column but they are small items compared to the diff), in the car and it didn't want to be in there!!!!.
Old 08-14-2011, 03:46 PM
David Hodgson's Avatar
Wink
Correct - if it were a Ford, you would have known to build it stronger in the first place
SLIPRY
Old 08-14-2011, 07:40 PM
Tenrocca's Avatar
Not sure your making the point you think you are there Eve?
Old 08-15-2011, 06:21 AM
Talking
The suggested point --perhaps -- That the ford would have broken itself before damaging anything else -- or, if not itself, then it didn't have enough grunt to break anything either
All in jest tho --based on grenaded Windsors in Qld over the last 12 months or so.........
Old 08-15-2011, 02:14 PM
Wazza's Avatar
Thanks for the "Heads Up" TL
I've got the same rear end going into the new Cobra...( Ford Thunderbird IRS )
I see the problem , and have taken some steps to re-enforce the area.
Under load, the front of the diff PULLS UP, and the back PUSHES down....and the ORIGINAL set up for these Ford Thunderbird rear ends probably had the mounting points ABOVE the front of the diff, so under load it would be PUSHING against the mounting.
In any case.....some extra plating in that area will do the job.
Warren.
Old 08-15-2011, 03:16 PM
C'mon Eve, I know one in a little red DRB that seems bullet proof
SLIPRY
Old 08-15-2011, 03:26 PM
SLIPRY
Old 08-15-2011, 04:55 PM
Wazza's Avatar
David...
I'm not sure if you know....but I'm pretty sure you're chatting with Chris...not Yve.
Chris is the stirrer in the family !!
Warren.
Old 08-15-2011, 06:06 PM
Waz, I thought it was a strange post for Yve.
Hi Chris, have you got to wear a skirt to use Yve's login?
You coming to Goulburn? Might see you there.
SLIPRY
Old 08-17-2011, 11:31 PM
Heres the guilty bit taken out from the car for all to see. Apparently Warwick is looking into it.
