Old 10-14-2011, 06:15 AM
WKB's Avatar
WKB WKB is offline
Default The Hoops are Getting Bigger
I hear that the RTA (NSW)require test results for the Side impact / Side Door Strength (ADR29 )
Would this be a crash test or a simulated test ?
Do kit builders supply these tests?
Has anyone from NSW building an ICV been asked for this test?
Has this been asked for in other states?
I don't remember this being a requirement in Qld when my cars were registered.
Warren
Old 10-14-2011, 06:42 AM
Default re intrusion bars
I'm at work right now but I think my engineers report mentions side intrusion and the requirement to have intrusion bars fitted....the RMC came with them fitted in 2002.
I'll check later.
Old 10-14-2011, 01:54 PM
Merv and Sharon's Avatar
And in Harrisons since 2008 at least.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
Old 10-14-2011, 06:55 PM
WKB's Avatar
WKB WKB is offline
I am not saying, do you need intrusion bars in doors, that is a given and is explained well in ADR 29.
What I am saying is that a report is now required to the effectivness of them by a crash test or calculated by a simulated test.
You just can't put steel in the door as per ADR 29 and say you have intrusion bars. Now you have to prove they are effective.
Warren
Old 10-14-2011, 07:18 PM
I know that in 2008 my engineer needed photos and details from Classic Revival to check. I am assuming that he had to do calculations to prove that they were suitable.
He also needed detail about the hinges and locks to make sure they complied.
It will be a big problem for new builders if they insist on testing now!
Ben
Old 10-14-2011, 08:36 PM
Zedn's Avatar
Testing of side intrusion bars is not a requirement. The RTA provide exemption for the testing requirement of the ADR but not the performance requirement. The engineer needs to provide evidence that they have assessed the adequacy of the structure by comparison to a production vehicle, calculations or FEA. They cannot just say 'the car has side intrusion bars - tick'.
According to the RTA, the problems that ICVs have been having in the last 2 years is attributed to engineers approving things based on visual inspection with no work being done to provide evidence for compliance. Its the same for suspension mounts and any modifications made to factory OEM parts.
From the conversations i have had with people at the RTA from Safer Vehicles, they just want more evidence of compliance and not just visual inspections.
Old 10-14-2011, 11:59 PM
Baz's Avatar
Baz Baz is offline
What Liam says is absolutely spot on. Take it from me as I have recently been through that hoop. The Signatory Engineer must prove by way of calculations acceptable to the RTA, that the side intrusion bars or for that matter, any other modified OEM part, is capable of performing the duty that they are designed for and not just say they comply with the NCOPLVM.
Baz
Old 10-15-2011, 12:12 AM
Zedn's Avatar
Gday Baz,
Hows the leg? Have you been getting the cobra out to enjoy the new rego?
Old 10-15-2011, 12:35 AM
WKB's Avatar
WKB WKB is offline
This an extract from the email I read yesterday. I did remove the kit builders name and the type of ICV.
"but now the RTA require that I or the engineer produce some test results for the (Side impact / Side Door Strength ADR29 ) normally this is a crash test or a simulated test .
The kit builder's submission letter compares the ICV door to a Commodore which is now not acceptable"
This ICV uses factory hinges and door latches from a late model car.
Warren
Old 10-15-2011, 01:46 AM
Zedn's Avatar
I cant comment without seeing the full context of the email. Baz's car passed rego a couple of weeks ago and that didnt require side impact testing.
There are a few other ICVs that i am aware of and none have required destructive testing, but all require some sort of analysis to be conducted by the engineer.
Old 10-15-2011, 03:28 AM
Zedn's Avatar
I just went through my records and dug out a letter i recieved from the senior vehicle engineer vehicle standards RTA on 16/11/2010.
Extract:
'The RTA has allowed some alternatives to demonstrate compliance to applicable ADR's. The ADR which alternate means of demonstrating compliance is acceptable are as follows:
ADR31/01 - Brake Systems - alternative is RTA abridged brake test
ADR69/00 - Full frontal impact protection - alternative is labelling warning of possibility of degraded occupant protection
ADR72/00 - Dynamic Side impact protection - alternative is labelled warning of possibility of degraded occupant protection
ADR73/00 - Offset frontal impact protection - alternative is labelled warning of possible degraded occupant protection
I know you said ADR 29/00 which is not in this list, however ADR 29/00 under the heading 'exemption' states that vehicles that comply with ADR 72/00 are exempt from 29/00.
Old 10-16-2011, 02:29 AM
Yes Bernie you are right. Mine was assessed as comparable or better than the current production vehicles for that year...no tests or stats required in 2002.
