10-19-2011, 06:05 AM
NSW
LS3 throttle body measurement
Hi all,
I dont suppose anyone has an LS3 throttle body that they can measure the hole in the butterfly on? I just bought one second hand and it looks like the hole may have been drilled out. Perhaps if you can just try some drill bits and tell me what fits?
Thanks for the help.
Liam
10-19-2011, 06:14 AM
Vic
Ben in AU
10-19-2011, 06:29 AM
NSW
Crap!
You appear to be correct. I bought it off ebay and it said it was as removed from a VE Maloo. That will stuff up my idle and who knows what it will do to emissions.
10-19-2011, 07:00 AM
NT
Can you silver solder the hole?
Or maybe normal solder?
Cruising in 5th
10-19-2011, 07:30 AM
Ill
You can put a rivit in the hole
10-19-2011, 01:55 PM
NSW
Dave, my only concern is that it might warp the butterfly if heated.
Jerry, dont you thing turbulance might be an issue with a rivet?
10-19-2011, 03:11 PM
ACT
Maybe a piece of thin brass shim and a solder iron instead of flame.
SLIPRY
10-19-2011, 05:20 PM
NSW
Didnt your engine come with a TB Liam?
10-19-2011, 07:15 PM
NT
Yep, the heat was a concern for me, hence I added to try with normal solder and a big soldering iron.
Cruising in 5th
10-19-2011, 07:48 PM
Crap!
put a decent cam in it
how big is the hole?
www.ultimateconversionwiring.com.au
_
10-20-2011, 12:33 AM
NSW
Hi Andrew,
No my crate motor didnt come with a TB. LS3s were scarse when i bought it so i didnt complaint too much. Also it is not a regular crate motor as it came from a W427 HSV.
Double Dip, the hole is about 5mm. In you experience do you think it will make much difference to the idle?
Dave, i have some bars of solder. I was thinking about trying some light heat on the butterfly to warm it up and then melt the solder and rub it on. Kind of like lead loading. If i leave a thin amount on each side of the butterfly when i file it smooth, it should plug the hole without falling out. Not sure if it will work though.
I could always use some nead it. I dont think that would really do any damage if it did come loose unless i was unlikely enought for a valve to close on it.
10-20-2011, 01:11 AM
VIC
The butterfly is aluminum. You will have a hard time soldering it.
Just try it out before you go changing it. There may be enough adjustment in your idle air motor that it's not an issue.
Mike Murphy
Melbourne Australia
10-20-2011, 02:30 AM
NSW
Hi mike, pretty sure LS3 is brass or copper. Its gold.
10-20-2011, 03:20 AM
VIC
Possibly anodized?
Mike Murphy
Melbourne Australia
10-20-2011, 03:32 AM
The holes are only meant for early engines without electronic throttle control.
Larger cam etc makes life difficult for a limited IAC valve and programming.
Later electronic throttle bodies don't have holes.
10-20-2011, 04:21 AM
Vic
Hi Andrew,
huh? Don't W427 have LS7?
Ben in AU
10-20-2011, 04:23 AM
VIC
I think Liam means its the motor they pulled out of a standard HSV when they inserted the LS7's. I think I read that HSV had a heap of these LS3's as a result of building the W427's. Rgds Gregg
10-20-2011, 06:07 AM
NSW
Yes, they were the LS3s removed. Still has the fluids in it. No TB but does have the clutch.
Mike, I dont think its anodized as i can see the hole is gold right through. Do you think using some nead it would be a bad idea? I was thinking if i was to spread it out a bit on each side it would lock it in kind of like a rivet.
10-20-2011, 07:33 AM
the idle will be fairly high with this hole...
so you have a Brass bladed throttle body... make sure you have the correct ecu for it then..otherwise you will have problems
they drill holes in them to get the engine to idle at a decent speed when a big cam is inserted...
_
10-20-2011, 02:04 PM
NSW
I hope i have the correct ECU. I was told it was out of an LS3 with securities removed.
I was told this TB is also off an LS3.
Does this sound correct? Is there a number on the ECU to look for?
