Like Tree6Likes
  #121 (permalink)
Old 07-03-2012, 06:10 AM
Thanks again.
Do I need to keep it stock, or would the massflow system still be compliable?
I like the setup. Clean looking.
The engine my boss has got, I think is the single ohc model mustang motor from 2005, with an ali block. Would that be worth restoring?
JD
  #122 (permalink)
Old 08-08-2012, 02:21 AM
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
Hi Craig,
Are there any updates on your Pace 427 kit please? I'm very keen for any and all info you can provide.
Simon
  #123 (permalink)
Old 08-08-2012, 06:03 AM
400TT's Avatar
Simon, will have some photos in the next few weeks once you shift some of the parts from the production shop to the main assembly shop.
Things are still very busy, I wish I could put more resouces onto it.
www.absolutepace.com
  #124 (permalink)
Old 10-05-2012, 02:59 AM
Cobra Make, Engine: DRB 540
Hi Jaydee,
I am building a DRB540. I have no mechanical background and so I am learning all of the hard ways of doing things! My donor is a 2007 BF FPV. Almost perfect with 302kw engine, brembo brakes and 6speed zf transmission. So far, I have suspension in place and just about ready to mount engine (will need to 'clean it up' first).
I think the kit is really quite good. Bolts fit the designated design, so makes it easy for a first timer. I guess if you are experienced then his could be too 'easy' for you.
Hope this helps!
  #125 (permalink)
Old 10-05-2012, 07:39 AM
Good luck Chucky. But I've bought a Cobra half complete kit. I'm also in the process of fitting the engine. I've just made some engine mounts using shackle bushes.
JD
