Old 08-09-2012, 12:18 AM
Baz's Avatar
Baz Baz is offline
Default A Day at the Dyno.
Took the Cobra to Sam's Performance Tuning in Greenacre today for a Dyno tune. 348 rwh (259.5 kw) at 158kph and 532.5 FtLb (722.6025 Nm) of torque at 124kph. Pretty pleased with that. Also included some recent pics.
Old 08-09-2012, 04:12 AM
boxhead's Avatar
Lookin good Baz, will you take it to Goulburn?
Cruising in 5th
Old 08-09-2012, 04:15 AM
Baz's Avatar
Baz Baz is offline
Unfortunately No Dave. Will be in the Sates.
Old 08-09-2012, 04:33 AM
Modena's Avatar
looks great Baz! Did you have a stock tune before this, and do you have a "before" dyno graph?
Ben in AU
Old 08-09-2012, 03:48 PM
Baz's Avatar
Baz Baz is offline
No Ben this is the first engine tune and I don't have a before Dyno graph, but its simply purring now. Was running really rich before.
Old 08-09-2012, 07:37 PM
Sam knows his stuff.
Did you go mafless tune?
Old 08-09-2012, 08:48 PM
Modena's Avatar
agreed Sam knows what he is doing, but Baz are you saying there was no before run, or just that you didn't get a graph from it?
Ben in AU
Old 08-10-2012, 03:55 AM
Baz's Avatar
Baz Baz is offline
Sam is in his new premises and has his roller dyno in a sound proof, ventilated and enclosed room which looks like a huge spray booth. Apparently, the car was so far out of tune prior to strapping it to the dyno that he had to bring the tune up to the mark on his computer through the ECU. I don't think he ran it on the dyno until he was sure that he had everything correct on his laptop. I couldn't see him as the booth is enclosed. I only heard it revving to about 7000 rpm twice and that was towards the end of the session, so I think there was no 'before' runs done.
Old 08-10-2012, 04:30 AM
Modena's Avatar
quite probably. Places like Sams have been tuning LSx's for long enough that they can load up an existing tune that will be 95%, especially if you have stock internals, and then just tweek it to suit your specific donk.
Ben in AU
Old 08-10-2012, 03:29 PM
Baz's Avatar
Baz Baz is offline
That's right Ben, but it's not exactly stock internally. I just had a Comp XER273HR-14 Roller Cam with double Crane springs etc., installed. I just supplied Sam with the cam specs and he did the rest. That's why I've waited for nearly 12 months before going to the dyno.
Old 08-10-2012, 03:40 PM
Baz's Avatar
Baz Baz is offline
No. The MAF is still there and running as far as I know. He only charged me the $800 for the tune with no parts. If I had gone Mafless, there would have been additional items on the account****.
Old 08-10-2012, 05:57 PM
boxhead's Avatar
No extras for Mafless Baz.
But I don't think there are many power gains to be had from going Mafless, unless your chasing every last pony and needing a larger air intake.
Cruising in 5th
Old 08-10-2012, 06:18 PM
I have a LS3 in my HSV which has a Maf Tune, Air Box and Full 3" Exhaust System, 300kW @ the wheels. Lots of good tuners out there are getting great numbers from the LS engines.
Old 08-10-2012, 11:13 PM
Zedn's Avatar
Nice, is that a stock engine?
Old 08-10-2012, 11:40 PM
Yep Stock, just the bolt on mods. I have been thinking about heavier valve springs and maybe a cam upgrade.
Old 08-11-2012, 04:25 AM
Baz's Avatar
Baz Baz is offline
Dave,
If the MAf was removed, I would need a MAP Sensor to be fitted in lieu. That was the additional part I referred to, but I don't think it was worth all the drama.
Old 08-11-2012, 07:19 AM
Zedn's Avatar
The motor uses both a MAP and MAF sensor. The MAP sensor is located behind the throttle body on the drivers side.
I agree, there would be very little performance gain.
Old 08-11-2012, 05:22 PM
Gav's Avatar
Gav Gav is offline
Hi Baz, how are you finding you new cam? I have the XER 281 in mine and love it!
Did you fit a stall converter?
Powered by Cu
Old 08-11-2012, 07:04 PM
400TT's Avatar
Baz, they are great numbers.
Better off in the long term retaining the MAF.
Thanks for sharing.
www.absolutepace.com
Old 08-11-2012, 11:22 PM
if u remove the maf its the air temp sensor u need to re install
not the map
as for perforamce gains its all up to the tuner
and sam is the godfather for lsx tuning and what he said is gospel
my website
www.sideshowsperformancewiring.com.au
