Like Tree8Likes
Old 12-19-2012, 11:07 PM
Zedn's Avatar
Default Making progress!
Big day today. Got the body on without scratching the engine bay or motor.
Old 12-20-2012, 12:57 AM
Looks nice
Old 12-20-2012, 03:41 AM
Nice Job ! Keep up the good work. Lets see more pics. What is the colour ?
Old 12-20-2012, 03:48 AM
Zedn's Avatar
Colour is a slightly customised Yamaha motor bike blue pearl. It's really heavy on the pearl so I had to play around with different ground coats. Really happy with the colour. Looks awesome in the sun. Not going to paint the body for a while yet though.
Old 12-20-2012, 04:04 AM
Acrylic or 2-Pack ? Good move not to paint the bod until it's finished...too many opportunities to scratch the thing ! Make sure you have all the colour mix formulas or you could have a nightmare in the future....also it will make a future sale more convincing ! Top move having the similar colour in the gelcoat ...No stone chip stand out !
Old 12-20-2012, 05:01 AM
jcraigau's Avatar
Liam, looking nice!
I'll have to make a special trip up next time I'm in Sydney.
--JC
Old 12-20-2012, 11:55 AM
Zedn's Avatar
Rob, it's 2 pack debeers. I used their scratch resistant clear also for a bit more durability. Colours are all standard formula it's just the combination. This colour is really transparent and when used over primer doesn't cover. There was no ground coat specified so I tried putting it over different colours till I got a good finish. Ended up using black underneath.
Jamie the beer is always cold.
Old 12-20-2012, 06:22 PM
leroy17's Avatar
Nice finish on the engine and bits.... looks good.
Old 12-30-2012, 01:28 AM
Zedn's Avatar
Took a walk around video prior to putting the body on if anyone is interested. After doing this i added neoprene rubber to the top of the chassis. Excuse the music, had to comply with copyright laws.
cobra walk around - YouTube
Old 12-30-2012, 04:18 AM
sjelby's Avatar
Looking real good Liam.
Old 01-01-2013, 03:01 AM
Pills's Avatar
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
Looks great Liam.
What shocks and spring rates are you running in the rear?
I assume you will be using all four on the back. I like the polished look.
Old 01-01-2013, 11:32 AM
Zedn's Avatar
They are Alden Eagle shocks and springs. I will be using 4 on the rear, just haven't been able to afford them yet so kaput spacers in. Not sure. On spring rate yet. The once I have are not correct due to a design change after purchasing.
Old 01-01-2013, 07:06 PM
Default Great Work
Liam,
Great work, very neat and a credit to you.
Just be aware that this is the cleanest it will ever be
STIFFY
Old 01-01-2013, 09:45 PM
Zedn's Avatar
Originally Posted by stiffy View Post
Liam,
STIFFY
Yes i know. Its already dirty. The heat shields are polished on the underside. I couldnt help myself but i know i will regret it.
Old 05-26-2013, 02:44 AM
Zedn's Avatar
Made a bit more progress on the car over the past couple of months.
Got the radiator installed and made up some stainless steel pipes. I used a 66 mustang alloy radiator and 1.5" plumbing. Also added a line filler so the level was a up higher than the radiator. I cant get it higher than the heads but its close enough.
I made a start on my exhaust headers this weekend. Almost finished one side. Decided to go with 1 7/8 pipe. It is very tight, so took ages to get all the bends as tight as possible. I did my best to get the pipe lengths as close as possible but with such limited space it was a bit hard. These will be ceramic coated when finished. I dont have much clearance between the pipes and foot box. Might have to add a heat shield to protect the paint.
Any one got a source for 4 hole 1 7/8" flanges???
I have collectors that go down to 3" as shown in the pic (not yet welded), but am thinking i should add a 4 hole flange in between to allow for a track exhaust to be bolted on.
Mando likes this.
Old 05-26-2013, 03:06 AM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Looking good, Cool pipe work
Old 05-26-2013, 03:16 AM
Aussie Mike's Avatar
Nice work Liam, It's really coming together.
I made a separate set of headers for the under car exhaust. I figured i didn't want to make too many compromises with the side pipe headers.
My undercar headers were based on Corvette exhaust manifolds (cut down to fit). They were cheap to buy and tucked in close to the block. Several folks have used them for rego now in fact I'm not really sure who has them at the moment.
If you are careful with the routing of your pipes you can make the headers pretty easy to unbolt and remove. I can unbolt mine and take them out through the engine bay pretty easily. I also went with 1 7/8" primaries as they suit my cam and intake combo.
Mike Murphy
Melbourne Australia
Old 05-26-2013, 03:36 AM
Zedn's Avatar
Thanks Mike,
The corvette style wouldn't work on mine due to the chassis layout. I also have my motor mounted a fair way back and also the foot boxes quite big. All this adds up to the exhaust going forward and out instead of out straight to the side.
Are your headers stainless or ceramic coated? Also did you make the 4 hole flange or buy it?
Old 05-26-2013, 03:59 AM
The headers are ceramic coated mild steel. I got the 4 hole flanges from Daren Difillipo in Melton Vic.
Mike Murphy
Melbourne Australia
Old 05-27-2013, 08:01 PM
PeterAllen's Avatar
Liam - You might try Best Mufflers at Carlton for those flanges. I could pick them up and you could collect them anytime.
I fully understand the enjoyment that goes into posting any progress on the car. In most cases it represent hours and hours of thought, research, hard yakka, lacerations & bruises, AND money. The posts provide comfort to other builders that we are not alone.
