questions
- » Blogs
- » Image Gallery
million posts!
November 2025
| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
2Likes
Post By Zedn
Post By Treeve
04-12-2013, 07:38 PM
qld
Cobra Make, Engine: venom motorsports /ls1 auto
position of roll bars
help guys i'm just starting to set up to drill holes for my rollbars ,& as its a venom motor sports
yes a mr tuckers I have no reference points to go on accept 100mm from inside edge of rear cock pit [ rear fire wall ]
so do I pick centre of head rest or slightly off centre
what lay back on the hoops
level to top of wind screen ? FOR HEIGHT
as its raining// so I can dummie fit, SO as to get them cut & welded thanks a head
ROB
not all your babies are your children
Advertising
04-12-2013, 08:01 PM
vic
If you want to race it, 50mm above your helmet is the go.
Depending on your seat height that may look a bit high though.
Powered by Cu
04-13-2013, 12:39 AM
NT
Mine sits "high" as I wanted the 50mm above head height.
Here is an old pic showing height with original seats when I attended my first Nationals.
Cruising in 5th
04-13-2013, 03:19 AM
VIC
My understanding is that you should draw a line from the top of the roll bar to the top of the front mud guard and your helmet should be under that?
Dave - you need to slouch when you roll over
Me I am a short arse so mine is ok :-)
Reason: added comment about shortarse
04-13-2013, 03:58 AM
NSW
Why? Your fibreglass guards won't hold up the front of the car
04-13-2013, 04:37 AM
qld
thanks for your in put but i need to know where to put the holes & what spaces are needed ? what lay back on the hoops
if you have pics that would help
thanks ROB
04-13-2013, 04:42 AM
Vic
Rob does your chassis any provision for mounts already, or are you truly starting from scratch here? I can go get some details off mine, just want to know what exactly I should measure.
Ben in AU
VIC
True, I hadn't thought about that
04-13-2013, 05:56 AM
QLD
I think the angle they lay back is 8 degrees.
04-14-2013, 01:18 AM
qld
Modena as you know we have no mounting point on the chassis .. so yes from scratching of head does apply
wazza thanks 8 degrees helps a lot
now centre of seat area or just off centre .. hoops I have are 298 mm centre/ centre of 50mm x4mm alloy hoops
thanks ROB
04-14-2013, 05:44 AM
NT
For looks it would be good to centre behind seats
Cruising in 5th
04-14-2013, 06:10 AM
NSW
Cobra Make, Engine: Dax
Guys,
Here's the link to the CAMS regs for roll bars / cages. The 50mm detail is on page 12. Good information is worth it's weight in saved money through re-work.
http://www.camsmanual.com.au/pdf/10_...e_J_2013-5.pdf
Treeve
04-14-2013, 06:59 AM
QLD
If you're building a replica Cobra....build it to look like a Cobra.....
If you are building a race car...then you should follow the CAMS guidelines.
04-14-2013, 03:37 PM
NT
My opinion too Wazz, if building a race car, build a cage.
Cruising in 5th
04-14-2013, 04:22 PM
When too many bars is never enough.... Just chuck a few extras in for good measure!
04-14-2013, 09:32 PM
Mattyboy...looks like the new rollercoaster at Dreamworld
