Old 05-20-2013, 03:26 AM
Gav's Avatar
Gav Gav is offline
Default Accusumps
I am fitting an Accusump with the install of my new motor and are after ideas for fitting it up.
Has anyone got pics of their install they are willing to share?
Powered by Cu
Old 05-20-2013, 03:45 AM
beauies's Avatar
Cobra Make, Engine: have brakes, diff, gearbox, steering rack, gear stick, door locks, CR chassis 3518
On my ute i have it t-ed into my oil cooler line with the canister mounted in the rear tray i have installed it with a ball valve, so i only turn it on when i go to the track or the like.
Old 05-20-2013, 04:19 AM
undy's Avatar
One from across the pond...
It serves for pre-lube duties only. My modded C6 Z06 is the track capable ride of choice.
Too many toys?? never!
Old 05-20-2013, 04:39 AM
750hp's Avatar
Scotty OZVENOM mounted mine behind the radiator with a cable operated manual valve and the same clamps as undy. Worked like a champ
Craig
Old 05-20-2013, 05:13 AM
Mrs flatchat's Avatar
Cobra Make, Engine: DRB, FORD 302W,T5
Wink
I have one with the solenoid valve which can be controlled automatically with a pressure switch or manual over ride.
I prefer a manual tap tho --just less things that bugger up
The tap needs to be handy to the driver and needs to be discreet, as these things aren't supposed to be in the cab.
Plumbing :--- from the engine -- through the filter --through the cooler (optional) -- from the cooler or filter a non return valve then a T from the accusump to the engine.
The poor mans dry sump is good but it doesn't fix oil surge !
Old 05-20-2013, 03:31 PM
Gav's Avatar
Gav Gav is offline
Thanks folks, I think I will be fitting it on the front cross member down low.
I don't run an oil cooler so it will get plumbed straight into a port next to the oil filter.
I also bought mine with the solanoid and pressure switch, the pre oiling thing is questionable but can't hurt, but given it doesn't run too often might be a good thing.
Powered by Cu
Old 05-20-2013, 03:47 PM
Default Accusump
Gav, I used a one way valve in the hose on the oil cooler side of the "T" junction where my accusump plumbs to, to avoid sending oil back down the line towards the cooler rather than into the block where its supposed to go.
Spookypt
Old 05-20-2013, 05:37 PM
Gav's Avatar
Gav Gav is offline
Thanks Spook
Powered by Cu
Old 05-20-2013, 06:13 PM
Default Return Valve
I just read Mrs Flatchat response and he mentioned the return valve.. Soz Chris for the double up.
Gav, I'm hoping to get up and work on my car this weekend so I'll see if I can grab you a part number for the non return valve.
matt
Old 06-02-2013, 03:34 PM
Sorry for the delay Gav....
Old 06-02-2013, 05:28 PM
Gav's Avatar
Gav Gav is offline
Thanks Spook
Powered by Cu
