Like Tree64Likes
  #61 (permalink)
Old 08-26-2013, 03:14 PM
OZCOBRA's Avatar
Others might suggest "just putting a FORD in it to slow him down!!"
... But being a Commodore things will just fall off it!!!
boxhead likes this.
  #62 (permalink)
Old 08-26-2013, 04:59 PM
Towmaster's Avatar
This standard 6 litre is just the 'getting to know the car' engine. I have a Comp Cams 224/230 cam to go in it. Everything else is standard (DOD / AFM removed) When I get used to it I will 'do a Gav' and put in a 416 'ish' cube engine. That should have similar horsepower to the intended V8 Supercar engine, but with a mountain more torque.
OZCOBRA likes this.
  #63 (permalink)
Old 08-29-2013, 05:30 AM
750hp's Avatar
Anything to stop you from putting a responsive little hair dryer on the car and having all the power and torque you could wish for (still with your stocko motor)?
It's coming along nicely Ash.
Craig
  #64 (permalink)
Old 08-29-2013, 06:01 AM
Towmaster's Avatar
Thanks Craig.
I have thought about turbo & supercharging but would prefer to keep it simple & just utilize bigger cubes.
Don't have to worry about intercoolers etc & can possibly run in 2A sports cars if I add another seat. It has a 6 litre engine, which is the same as the VZ came out with. Still investigating what class I can run in. I know I can run as an invited spots sedan.
  #65 (permalink)
Old 09-24-2013, 10:34 PM
Towmaster's Avatar
Ok bit of an update, nothing too exciting...
I had to buy an 'air lance' to get the air jacks to work. $517...... That's just the thing you see them push into the side of the car to jack it up..... And $340 for a Nitrogen regulator...... I 'hope' that is the last of the 'special' items...
I decided to fit a removable steering wheel, it makes it a whole lot easier getting in and out of the car.
And with the wheel off
Aussie Mike likes this.
  #66 (permalink)
Old 09-24-2013, 10:40 PM
Towmaster's Avatar
I have also been plumbing the dry sump stuff.... Half the battle was deciding where to run all the lines.
I apologise for the quality of these photos. I took them from the bottom of the 'pit' and you can't really see everything, but it does give a good overall view.
There is a remote oil filter in there but no oil cooler as yet. Apparently it's not as important as the water temp because there is a big aluminium tank that holds about 10 litres in the boot..... I will see how it goes and fit a cooler if necessary.
I have had the ENZED guy out to have a look. He is going to make up some lines for the air lance etc and plumb in the power steering, clutch line and gearbox cooler. He had to order in some parts so hasn't started yet.
I have booked in with Peter Beehag to get the pipes done in late October so after that I will pull the engine out and get the wiring done and put the Cam / DOD delete stuff in it then.
  #67 (permalink)
Old 09-24-2013, 11:01 PM
Mate, with those "special Items" being applied to the build...what items are you having to buy to offset and contra the deal to enable you to stay married???????
As far as the build goes is that the normal position for the steering rack....or is that a V8 supercar thing for maximising steering/suspension adjustment geometry?
  #68 (permalink)
Old 09-25-2013, 12:29 AM
Towmaster's Avatar
As for the money thing, let's just say I have sold nearly $6k worth of stuff off the wreck.... Mostly for cash....
I am pretty lucky I the fact that my wife earns a lot more than me.... Things might change when we have kids.....
As for the steering.... Not sure, it's the only one I have owned so I don't have another to compare it to. Most of that stuff is controlled so I am guessing it is a standard component.
  #69 (permalink)
Old 09-25-2013, 12:39 AM
Cobra Make, Engine: Absolute Pace 427 SC
Hi Ash
We used to have a sign on the fridge it read.
We have the most expensive toys they are called KIDS.
But after having them i wouldn't have it any other way
Brad
There is nothing better than a cold beer
  #70 (permalink)
Old 09-25-2013, 07:09 PM
Towmaster's Avatar
I have been googling 'Harrop 2300' and found they can produce quite a bit of power / torque...... for not a lot of money....... and it would just be a bolt on........ hhmmmmmmm
Wazza likes this.
  #71 (permalink)
Old 09-25-2013, 09:16 PM
Ash, how does this affect the class you want to race in?
  #72 (permalink)
Old 09-25-2013, 10:59 PM
Towmaster's Avatar
Technically...... with CAMS......... I have no Class (insert Wazza joke here)
Can't run in V8 supercar (not original engine and box)
Can (with an exemption) run in Sports Sedans (Larry Bar is the issue apparently) as long as the engine is under 6 litres. (Although another exemption could sort that out)
Could possibly (with changes to the car) run in 2A sports cars.... because it is a production based car with a production based engine.... VZ Commodores did run the 6 litre V8.
With a blower on it I would need multiple exemptions.... lol
If i run with AASA I just turn up, they check the car is safe and I go racing. EASY!!!
There is plenty of AASA sports and sedans races up here, about 9 a year i think.
I have spoken to the guys that run the CAMS sports sedans series up here and they said I would be welcome anytime. As long as i don't win anything.... ha ha just jokes.
All in all I should be able to find somewhere to have some fun. At the end of the day that's what it is all about! We do it for the enjoyment of the sport. If it was about making money no privateer would ever enter a race.
  #73 (permalink)
Old 09-25-2013, 11:25 PM
I'm happy to expand on that and say if it was about making money you'd not go near anything that has the word RACE before it...
Race car, Race track, Race parts, Race trailer, Race license, Race u off in the trailer, Race home! It's all bad and at best wallet lightening...at worst divorce... Although some may think that's actually a better option!
Love the pics and details...keep them coming!
OZCOBRA and Cobra01 like this.
  #74 (permalink)
Old 09-27-2013, 02:00 AM
Towmaster's Avatar
Got myself a little bottle of Nitrogen today....
  #75 (permalink)
Old 10-18-2013, 05:53 AM
Towmaster's Avatar
Got the air jacks all operational, pretty cool stuff.
The car is heading to Peter Beehags tomorrow for a set of stepped 4 into 1 headers and some double up jack stands to get the car right up off the ground.
Will post some photos of Peters work when I get the car back.
boxhead likes this.
  #76 (permalink)
Old 10-28-2013, 06:33 PM
Towmaster's Avatar
Hopefully should get the car back this weekend, then will have to pull out the engine and box etc to rebuild it.
I have found a few photos of the car in earlier years. It was built as a VT Commodore in 1999 by Derek Van Zelm of Motorsport Engineering Serivces in Melbourne. He raced the car in 2000 in the Shell series and in later years in the Konica series.
And some of it on track at Bathurst in 2003.
boxhead, OZCOBRA, Gav and 1 others like this.
  #77 (permalink)
Old 10-28-2013, 06:36 PM
Towmaster's Avatar
Here are some other photos of the car in a different colour scheme.
boxhead, Gav, Mad94d and 1 others like this.
  #78 (permalink)
Old 10-28-2013, 07:58 PM
boxhead's Avatar
Love it Ash, great to see some old pics of it in other colors.
Cruising in 5th
  #79 (permalink)
Old 10-30-2013, 06:17 PM
Towmaster's Avatar
Ok another photo I found............. Drew Russell campaining the car sometime in 2008.
boxhead and Gav like this.
  #80 (permalink)
Old 11-03-2013, 07:04 PM
Towmaster's Avatar
Got the car back on Sunday after the Cobra breakfast. Had to pick up the trailer from Craig's workshop after the breakfast and it seems he always has Cobra people there. Even people from interstate....... And royalty too there was a large mix of people there, Kings, Queens, Presidents.... really stepping up now.
Anyways where was I ......... oh yeah. Picked up the car from Peter Beehagss shop. Job looks good, 4 into 1 stepped headers. Inch and three quarter into inch and seven eighths into 2 inch into a merge collector then back out to 90mm (each side). Should breath pretty well.
The car as I unloaded it this morning.
The drivers side pipes
Passengers side pipes
