January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-11-2013, 02:25 AM
gjkrv8's Avatar
Default Non Cobra question
Apologies for non-Cobra question but I know there are plenty of car savvy people here who might have experienced or know of this issue and may be able to point me in the right direction.
My sons VU V6 UTE did a wierd thing tonight.
He says "The Alt light came on and the power steering did work" he also said brakes were funny as well but I am not sure about this.
I immediately said fan belt.
He was only about a K from home and he stopped the car and re-started it and all ok now.
I thought maybe slipping belt. Oil on belt etc.
I had a look just now and no oil etc. Started car all ok now. Belt ok, Wierd.
Any ideas??
Gregg
Gregg
Old 06-11-2013, 06:06 AM
Gav's Avatar
Gav Gav is offline
It stalled?
Powered by Cu
Old 06-11-2013, 06:17 AM
Mrs flatchat's Avatar
Cobra Make, Engine: DRB, FORD 302W,T5
Talking
It stalled reset, restart carry on irregardless
Old 06-11-2013, 06:28 AM
OZCOBRA's Avatar
Originally Posted by Gav View Post
It stalled?
It's a Holden!!!!!.....nuff said!!!
I know the problem!!!.... it's Missing 2 cylinders!!!
Old 06-11-2013, 06:34 AM
gjkrv8's Avatar
Its an Auto :-)
Old 06-11-2013, 04:14 PM
Default Alternator
Gregg,
Check to see if they run the same alternator as the GenIV's (140AMP) as I
had a similar issue when the alternator got wet.
STIFFY
Old 06-11-2013, 04:54 PM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Gregg
as per stiffy they can get water issues un plug the plug on the rear of the alt . & replug in that's all the auto elect did for my vx & vy ser2 utes went it happened
rob
not all your babies are your children
Old 06-11-2013, 05:00 PM
scootter's Avatar
Cobra Make, Engine: SPF #1436 514
I would bet it died. My daughters Jeep Cherokee did the same thing. It dies then the alternator light comes on, steering is hard, brakes won't work right. It started back up and drove it home. I had to replace the crank and can sensors.
Scott
Old 06-11-2013, 05:57 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Scott
Agreed, happened to my old VZ Adventra, stalled, left the battery terminal off for an hour to reset the ECU and then all was good until i sold it 20,000klm later.
Old 06-12-2013, 12:49 AM
gjkrv8's Avatar
Thanks everyone for your tips. Will keep an eye on it for now until it happens again. Will check alt connections etc on the weekend. Cheers Gregg
Old 06-12-2013, 02:14 AM
Cobra Make, Engine: Robnell Blown LS1
Would be worth plugging in to the OBD to see if any codes are thrown. Local auto elec could do that for you in 5 mins.
Should cost bugger all for them to check it for you.
I have one but unfortunately am away at present otherwise we could have had a look..
Old 06-12-2013, 04:14 AM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
I'm in the western suburbs if you need a code reader
Old 06-12-2013, 05:29 AM
gjkrv8's Avatar
Thanks Guys I have a code reader. (got the PLX Kiwi Wifi one with the DashCommand iPhone tool). I will have a look and see if there are any codes.
Gregg
