06-11-2013, 02:25 AM
VIC
Non Cobra question
Apologies for non-Cobra question but I know there are plenty of car savvy people here who might have experienced or know of this issue and may be able to point me in the right direction.
My sons VU V6 UTE did a wierd thing tonight.
He says "The Alt light came on and the power steering did work" he also said brakes were funny as well but I am not sure about this.
I immediately said fan belt.
He was only about a K from home and he stopped the car and re-started it and all ok now.
I thought maybe slipping belt. Oil on belt etc.
I had a look just now and no oil etc. Started car all ok now. Belt ok, Wierd.
Any ideas??
Gregg
Gregg
06-11-2013, 06:06 AM
vic
It stalled?
Powered by Cu
06-11-2013, 06:17 AM
Qld
06-11-2013, 06:28 AM
Vic
Originally Posted by Gav
It stalled?
Originally Posted by Mrs flatchat
It's a Holden!!!!!.....nuff said!!!
I know the problem!!!.... it's Missing 2 cylinders!!!
06-11-2013, 06:34 AM
VIC
Its an Auto :-)
06-11-2013, 04:14 PM
Vic
Alternator
Gregg,
Check to see if they run the same alternator as the GenIV's (140AMP) as I
had a similar issue when the alternator got wet.
STIFFY
06-11-2013, 04:54 PM
qld
Gregg
as per stiffy they can get water issues un plug the plug on the rear of the alt . & replug in that's all the auto elect did for my vx & vy ser2 utes went it happened
rob
06-11-2013, 05:00 PM
I would bet it died. My daughters Jeep Cherokee did the same thing. It dies then the alternator light comes on, steering is hard, brakes won't work right. It started back up and drove it home. I had to replace the crank and can sensors.
Scott
06-11-2013, 05:57 PM
vic
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Scott
Agreed, happened to my old VZ Adventra, stalled, left the battery terminal off for an hour to reset the ECU and then all was good until i sold it 20,000klm later.
06-12-2013, 12:49 AM
VIC
Thanks everyone for your tips. Will keep an eye on it for now until it happens again. Will check alt connections etc on the weekend. Cheers Gregg
06-12-2013, 02:14 AM
vic
Cobra Make, Engine: Robnell Blown LS1
Would be worth plugging in to the OBD to see if any codes are thrown. Local auto elec could do that for you in 5 mins.
Should cost bugger all for them to check it for you.
I have one but unfortunately am away at present otherwise we could have had a look..
06-12-2013, 04:14 AM
VIC
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
I'm in the western suburbs if you need a code reader
06-12-2013, 05:29 AM
VIC
Thanks Guys I have a code reader. (got the PLX Kiwi Wifi one with the DashCommand iPhone tool). I will have a look and see if there are any codes.
Gregg
