November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-08-2013, 03:39 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
Talking what battery
ok i'm after a battery now so what do every one use as i;m only going to cruise & may run it around the track as a 1 off thing
so i was thinking a odessy battery [ red]
or do i get a standard battery from a ve commodore or / falcon v8
any ideas are always a help
rob
not all your babies are your children
Old 07-08-2013, 03:53 AM
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
rob
Hows it going Rob, I went with a standard battery, as I can top up the fluid as I go, it spends a lot of time unused, and I hear that's bad for the non top up ables to be rarely used
Old 07-08-2013, 05:21 PM
letsboogie351's Avatar
Cobra Make, Engine: Kenmer with Ford Quad Cam Boss 260
Rob, I just went with an ordinary sealed battery with high cca rating. If you're like me you won't have to worry about it sitting around. Every chance I get to sit my ar*e in the seat even if it is only for 10 or 15 minutes, I take it out on the road.
Doug
Old 07-08-2013, 05:31 PM
boxhead's Avatar
Get a sealed unit with correct trickle charger.
Unless the battery is easily accessed and you dont mind having to jump start it.
Cruising in 5th
Old 07-08-2013, 06:07 PM
750hp's Avatar
I agree with Box. As you're not running monster compression requiring a huge cold cranking amp rating on the battery, I'd say the trickle charger is more important than the type of battery. I use the Ctek charger and it not only maintains my car and motorbike batteries perfectly, but it also kicked an Odyssey battery into life after it had been flat and unused for 5 years. Ctek MXS5.0 Battery Charger
Craig
Old 07-08-2013, 09:55 PM
gjkrv8's Avatar
I also agree with Craig and Boxhead. I have a normal sealed battery and just put it on the trickle charger when not in use for more than a week. The battery guy told me the trickle charge is good as it discharges and charges which is better than just a straight charge approach. Seems to work fine for the last 5 years. Touch wood. Cheers Gregg
Old 07-08-2013, 11:36 PM
boxhead's Avatar
I have the same charger Craig, was recomended to me buy AutoSparky mate.
Cruising in 5th
Old 07-09-2013, 01:02 AM
Baz's Avatar
Baz Baz is offline
I have an Odyssey Battery and I couldn't be happier. After each drive, I turn off the battery isolation switch and can leave it for 2 to 3 months, then switch it back on and away it goes. Not a problem in the world.
Baz
Old 07-09-2013, 02:39 AM
baz
do you have a separate live circuit to keep the computer alive before the isolator as I have a isolator but run a separate live just to keep the computer alive
Old 07-09-2013, 02:43 AM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
i have a calcium battery in mine, but only because it came with it, but the date is over 6 years old, so not to bad. dont need a charger with mine, because i drive it every weekend, even in this freezing weather in albury. i think it got to a high of 11 deg c last weekend.
