December 2025
Like Tree1Likes
  • 1 Post By schipps
Old 08-13-2013, 01:14 PM
schipps's Avatar
Default Soft Top Windows
Hi all, i have just had my soft top made and we are at a standstill on how to attach the windows to the windscreen.
So over to you guys and girls, if you have any, can you please attach photos on how your upholsterer attached the windows to the windscreen i.e. channel, clips...whatever...
I am talking about "soft" type zip in windows that attach by zip to the soft top itself.
regards
Mick
Schipps
Old 08-13-2013, 05:42 PM
BMK's Avatar
BMK BMK is offline
Mine just fold in once closed.
Bernie Knight
Old 08-13-2013, 06:03 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Why won't the OEM type work?
John
Old 08-14-2013, 02:57 AM
schipps's Avatar
Default soft top windows
John
John,
what OEM ones??
Mick
Schipps
Old 08-14-2013, 02:58 AM
schipps's Avatar
Default Soft top windows
Bernie,
Yes, but how are they attached to the windscreen? Or do they just flap at the front???
Mick
Schipps
Old 08-14-2013, 04:53 AM
07cob's Avatar
Mick
A bit hard without a photo but mine attach to the soft top with a zip which runs to the top of the windscreen and at the bottom there is a tab that attaches to a press stud on the outside of the windscreen escutcheon. Between the top and the bottom, the window extends forward enough to tuck inside the screen. I didn't think it would be much good but appears reasonably stable. If that doesn't make sense, I'll grab a photo tomorrow.
Geof
Old 08-14-2013, 01:04 PM
schipps's Avatar
Default attachment?
Originally Posted by 07cob View Post
Mick
Geof
Geof,
Long time no see mate!
Thanks for the explanation, a photo would also be great if not too much trouble?
thanks Geof.
regards
Mick
Schipps
Old 08-14-2013, 03:06 PM
Grubby's Avatar
OE style windows are held to the door with two or 3 pins and open with the door.
John
Old 08-14-2013, 03:43 PM
David Hodgson's Avatar
John
These are the hard framed perspex sliders, Schipps has soft zip in type
SLIPRY
Old 08-15-2013, 04:05 AM
BMK's Avatar
BMK BMK is offline
Sorry,
Yes, mine are attached with three pins into the door. When the door opens they open with it.
Flat piece of metal along the door with three pins. Tube frame around the outer edge. All covered in quality English vinyl as original - sourced ex Healey cars.
I have a hard plastic strip sewn into the material around above the tube frame. This is quite strong and does not flap.
When the door closes I just pull the leading front edge in behind the window post. Even in heavy rain it does not let water in.
Bernie Knight
Old 08-15-2013, 06:18 AM
schipps's Avatar
Sorry,
Thanks Bernie, but i am after info on the soft zip in windows, not the hard framed ones.
Mick
BMK likes this.
Schipps
Old 08-15-2013, 11:16 AM
CHANMADD's Avatar
Ok..........I made mine like yours........originally I used Velcro.....the soft side , I used a strong contact glue , trimmed fit the inside of the windshield post. The other side of the Velcro....the rough side....I stitched to the side window.........When you open the door you unzip from the back and the Velcro stays connected...Been over 100 mph.. many times.....stays put and remains water tight.....got to seal the posts where they go through the cowl......
Old 08-15-2013, 11:19 AM
BMK's Avatar
BMK BMK is offline
Mick
Aaaah - makes sense.
However, the frames allow you to run side curtains without the top on - just a consideration as I have used mine without the top on cold sunny mornings.
Also they don't flap around all...
Try Rob H. member of the Victorian Cobra Club, as he has made a number of sets including the zip in roll up type and frame types.
Bernie Knight
Old 08-15-2013, 01:31 PM
CHANMADD's Avatar
Yea ...i would prefer the framed side windows.......I just dont like the holes in the door.......also the soft ones store easily too......
Old 08-18-2013, 03:26 AM
07cob's Avatar
Default Photos
Mick
Sorry for the delay ... uploading photos from iPad is a pain (read not possible!)
Here is a couple of images that show how the window attaches at the front:
There are a few more photos of the window in my gallery.
Hope this helps
Geof
Old 08-18-2013, 10:08 AM
BMK's Avatar
BMK BMK is offline
Geof
I was just looking through your gallery. Yes the way you have done the side curtains is a neat option. Probably meets Micks needs for sure.
I have my side curtains as a solid flat storage option in a small bag and the hood bows in another so the soft folding option was not required.
Bernie Knight
Old 08-18-2013, 01:09 PM
schipps's Avatar
Mick
Hope this helps
Geof
Geof,
Excellent, thanks. Will show them to the upholsterer.
regards
Mick
Schipps
Old 08-19-2013, 04:13 AM
Cobra Make, Engine: Harrison no. 9, Pace GT40 no. 14 build
Mick,
Hope all is well, it's been a while since catching up but I managed to break my leg at work last month and have been laid up since then (another 4 weeks to go), haven't been able to drive the Cobra since June but can now manage the accelerator and brake pedal again.
I have just taken a few shots of the soft top I had made up fyi, the main roof incorporates narrow side sections that attach to the windscreen frame, the side windows then zip to those pieces, works well even at speed (btw I had to attach the clamp to the windscreen frame rather than the soft top due to limited space on the channel)
Hope to catch up soon.
Derek
Old 08-19-2013, 05:20 AM
schipps's Avatar
[quote=dc7531;1258191]Mick,
Derek
Derek,
Hope the leg heals well mate!
Thanks for the info and photos of how you attached the windows to the soft top.
Many thanks
Enjoy the break...
regards
Mick.
Schipps
