Like Tree327Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
  #61 (permalink)
Old 01-06-2014, 12:19 AM
Zedn's Avatar
I didn't buy the Lokar switch as it seemed expensive for what it is. I figured I'd make my own. I'll post a pic once I get it set up.
Michael
Yeah I think mine was about $20 about 3 years ago. You could get a momentary switch from jay car, but for $20 I didn't think it was worth the hassle. It's completely useless though. I need to modify the bracket to make it work.
Liam
  #62 (permalink)
Old 01-06-2014, 12:46 AM
Aussie Mike's Avatar
They want about $40 or $50 now for a $4 microswitch and piece of bent metal. A bit steep in my book.
Mike Murphy
Melbourne Australia
  #63 (permalink)
Old 01-06-2014, 01:58 AM
Modena's Avatar
Just closing out the beautiful brackets which Mike fabricated, now all installed on the car;
Aussie Mike, guye, mate and 5 others like this.
Ben in AU
  #64 (permalink)
Old 01-06-2014, 02:16 AM
Good to see them on the car Ben. Glad they all worked out OK.
Mike Murphy
Melbourne Australia
  #65 (permalink)
Old 01-06-2014, 03:49 AM
leroy17's Avatar
Awesome work there mike, machined alloy never gets old.
The above pics are metal porn, and those Penske shocks are class.
  #66 (permalink)
Old 01-06-2014, 03:59 AM
750hp's Avatar
Brakes look great!
Mike have you considered isolating the handbrake? Not sure if it was only my car, but I had my handbrake mounted on my M22 in the Arntz and it vibrated like crazy.
Craig
  #67 (permalink)
Old 01-06-2014, 05:25 AM
Originally Posted by 750hp View Post
Brakes look great!
That thought has crossed my mind Craig and it is something I'm concerned about. I shouldn't be any worse than the shift lever. I figure if it does vibrate too much I can re-bush the pivot pins in the mechanism to take all the play out. The mechanism is pretty tight though so hopefully will be OK.
Mike Murphy
Melbourne Australia
  #68 (permalink)
Old 01-06-2014, 12:53 PM
Zedn's Avatar
I mounted mine over the gearbox, but I just welded in a small shs frame to the chassis to mount to. I don't think the vibration would matter on yours too much the locking mechanism on the hand brake is pretty solid.
  #69 (permalink)
Old 04-09-2015, 06:19 PM
Neutral
Just a small update. I haven't made much progress on anything for a while. I've had some health issues. I'm better now so getting back into the shed.
Here's another brake conversion. This time it's Modena's rear brakes.
Ben's CR uses VE Commodore rear uprights. We've adapted Ford territory rotors from DBA which are 328mm in diameter which is a good fit inside a 17" wheel. Converting the rotors just meant re drilling the bolt pattern and machining a small spacer ring. The ring is to make sure the rotor's larger center bore is centered over the slightly smaller Holden hub spigot.
Ben sourced some very nice AP calipers to match his front ones however adapting them to the Holden hub proved tricky. The location of the mounting lugs on the hub means that a conventional dog bone mount wasn't going to work. Dave W had done the same conversion and hit the same issue. I ended up machining some L shaped brackets similar to Dave's to get around the clearance issues.
These started as a block of 38mm square 1020 cold rolled steel bar stock. The normal hot rolled bar stock you buy from the steel merchant is the same 1020 steel but the cold rolled version is a significantly stronger material. I had to make them from steel since they wouldn't have been strong enough in aluminium. Just not enough material there.
To get around the clearance issues the brackets use countersunk head cap screws to attach the caliper. I'm a bit of a fan of countersunk bolts as I like how they spread the load over a larger area and self center. It's just more work to machine parts to suit.
You can see from these pics why it was tricky to mount the calipers to the existing lugs.
Still got to trim the bolts to the right length.
Despite being made from steel the brackets turned out to be surprisingly light weight. There's a huge pile of swarf on the mill though as probably about 70% of the original block has been milled away to reveal them.
Now to get stuck back into my own projects.
guye, Chris L, mate and 8 others like this.
Mike Murphy
Melbourne Australia
  #70 (permalink)
Old 04-09-2015, 08:25 PM
very impressive i wish i had your skill and ability to think outside the box to sort out a problem . if i ever need machining done your the man lol pity you don't live in Adelaide
cheers dean
Aussie Mike likes this.
  #71 (permalink)
Old 04-10-2015, 02:46 AM
750hp's Avatar
Glad to hear you're on the mend Mike.
Looks like a cool way to get some impressive brakes in place. Dean, I totally agree that simply being a good machinist is only half the story. The ability to problem solve and create strong/practical solutions is critical. I have neither the talent nor the vision...
Craig
  #72 (permalink)
Old 04-11-2015, 03:07 PM
leroy17's Avatar
I never get tired of seeing work like this.
Can you imagine how many workshops that one may go to and be told 'nah mate, cant be done' or a host of other responses.
Good to hear that you are back in the shed, I am sure updates on your build will be not far away and look forward to more from the Aussie Mike shed.
Aussie Mike and Chris L like this.
  #73 (permalink)
Old 04-11-2015, 06:33 PM
Registered User
[quote=leroy17;1344818]I never get tired of seeing work like this.
I don't think it's a case of not being capable of doing the job, but more that most people don't want to pay what it's going to cost!
Regards.
Aussie Mike and Gav like this.
  #74 (permalink)
Old 12-05-2015, 07:06 PM
This post is probably a little premature but I'm pretty excited. I just acquired a CNC milling machine. I've been wanting to upgrade to a CNC mill for some time as it opens up lots of possibilities for things to make.
I had been investigating bringing in a machine from China but for the size of machine I wanted I didn't have the budget. A lot of the more affordable machines don't have a very big table or a lot of working area. Most of the cheaper used machines are huge or need a lot of work as they are flogged out. I found this very tidy 2nd hand machine locally which is about the same size as my current manual mill. I can also run it as a manual machine so I'll be able to sell my old mill and have one machine that does the lot.
Picking it up in a couple of weeks.
deano59, guye, boxhead and 7 others like this.
Mike Murphy
Melbourne Australia
  #75 (permalink)
Old 12-05-2015, 08:00 PM
indianamoon's Avatar
Cobra Make, Engine: B & B 289
Default mill
Hi Mike.
can't see which prototrak control your mill has. If it is one of the later ones, and you are able to input a .dxf file, that is definitely the way to go. I have two prototraks in the shop but sadly neither can do that. I do however have an Anilam control that will. We now use that machine more than any other mill in the shop and it is FAST and accurate. If your machines can take a dxf file, e-mail me and I will give you a few hints on making it work faster and smoother. Good luck with the new toy!!!!
Aussie Mike, boxhead and Gav like this.
  #76 (permalink)
Old 12-05-2015, 08:17 PM
Thanks Indianamoon. I'll take you up on that. This unit has a prototrak MX2e on it. It's only 2 axis but I figure it has the ball screws and the drives so it shouldn't take me too much work to modify it for a more modern controller. I've seen several retrofit kits for the 3rd axis too.
My current mill is a great machine but this one has a bunch of extra features that are a step up. It has a power draw bar and variable speed head. The plan is also to run the motor off a VSD.
I think it'll be a fun project just getting the whole thing set up and working how I want.
Mike Murphy
Melbourne Australia
  #77 (permalink)
Old 12-06-2015, 01:09 AM
Dimis's Avatar
Even if you gave that to me for free, I wouldn't know how to use it, or even what to do with it. I'm glad it's in your capable hands, I can feel the buzz of excitement in your post.
Congrats & enjoy!
  #78 (permalink)
Old 12-06-2015, 01:58 AM
Mike....you sure have got all the toys, and then some !! Good Stuff.
All sorts of possibilities now !! Muz
Aussie Mike and boxhead like this.
  #79 (permalink)
Old 12-06-2015, 02:14 AM
Modena's Avatar
That machine, right there, looks like a reason to pull the Cobra apart again Mike
Aussie Mike, guye and boxhead like this.
Ben in AU
  #80 (permalink)
Old 12-06-2015, 03:01 AM
LOL. Don't tempt me.
boxhead likes this.
Mike Murphy
Melbourne Australia
