Like Tree2Likes
  • 1 Post By Gav
  • 1 Post By BJ's Snake
Old 10-28-2013, 10:17 PM
Default Sway bars
I have a uncompleted CR which has a rear sway bar already installed. And from past advice, Am I better of not running any, or do I need one for the front as well?
JD
Old 10-28-2013, 11:11 PM
Gav's Avatar
Gav Gav is offline
You definitly need one for the front, but is optional on the rear
Powered by Cu
Old 10-29-2013, 03:40 AM
How did you get yours made? Some one mentioned that a rear sway bar makes it squirrely in the rear, being such a light car.
JD
Old 10-29-2013, 05:03 AM
Gav's Avatar
Gav Gav is offline
I will buy yours if you don't want it!
There is a pic of mine with the inside front wheel a couple of inches in the air at the Nationals and I would think a rear bar would help stop this from happening.
Not flogging it around a track would stop it too no doubt
One of the B Clubbers got a swag of front bars made years ago, pedders in Sydney somewhere made them from memory.
Powered by Cu
Old 10-30-2013, 03:41 AM
Phil Neale organised a run on front sway bars from Pedders at Hornsby. Great guys.
Not sure if they do 1 off but worth a call.
I had front and rear on mine, worked great.
Ben
Old 10-30-2013, 02:53 PM
David Hodgson's Avatar
Beejay, did I miss a post somewhere, your details suggest you have sold your car?
SLIPRY
Old 10-30-2013, 09:12 PM
sambo's Avatar
Gav, honest question - assuming that's your inside front wheel up in the air during a hard corner, what would a rear bar (reducing rear body roll) by itself do to fix that?
Old 10-30-2013, 09:42 PM
Gav's Avatar
Gav Gav is offline
There is a lot of body roll in the rear and the car is accelerating so lifting the nose and really leaning hard on the outside rear tyre, if it had a rear sway bar fitted it should (maybe) not roll as much.
I could probably put stiffer rear springs in it but that would not allow it to squat and hook up as well from a standing start.
Powered by Cu
Old 10-30-2013, 11:13 PM
sambo's Avatar
OK gotcyha. Maybe there are virtues to fitting a boat anchor after all.
Old 10-31-2013, 12:14 AM
David,
Yes, I sold my car a while ago. It is now lives around Bathurst. I am trying out some American muscle with a back seat and roof for a while!
Ben
Old 10-31-2013, 04:25 PM
Towmaster's Avatar
And also there is probably not enough droop in your front suspension......
Wayne Proctors car suffered the same affliction at the Nationals last year. Carried a front wheel all the way around the fish hook. Doesn't mean the car is slow, just probably not as fast as it could be. Depends what you want to do with your car. Regular street duties and the odd bit of track time wouldn't really warrant the use of a rear sway bar. Most Cobras have oversteer issues, put a rear sway bar on a car with oversteer and you get more oversteer...
Old 10-31-2013, 05:11 PM
Gav's Avatar
Gav Gav is offline
Mine has never had oversteer, but loads of understeer.
The heavier motor and bigger front tyres helped big time this year though.
Powered by Cu
Old 10-31-2013, 06:51 PM
Baz's Avatar
Baz Baz is offline
Hi Gav,
If your car has never had 'oversteer', what do you call that little incident at this year's Nats., which occured at the end of the 1/8 mile during your first run in the drags? It sure looked like oversteer to me.
Baz
Old 10-31-2013, 07:29 PM
Gav's Avatar
Gav Gav is offline
That was cold brakes, too much rear bias and s$$t I am going quick and hit the brakes too hard.
Over steer happens while going around corners Baz!!
Powered by Cu
Old 10-31-2013, 07:54 PM
Towmaster's Avatar
Oversteer happens when the rear passes the front.......
Just not whilst braking.....
I would have loved to see that Gav, the visible skid marks (as opposed to the ones in ur Reg Grundys) were quite spectacular!
Old 10-31-2013, 07:59 PM
Gav's Avatar
Gav Gav is offline
It definitly woke me up, I give you the tip.
Wazza likes this.
Powered by Cu
Old 10-31-2013, 10:47 PM
BJ's Snake's Avatar
I was marshalling at turn 10 when Gav had his little incident, heading straight for me...
Yep,woke me up too.
Gav likes this.
289 FIA Cobras RULE!
Old 11-01-2013, 05:24 AM
So I definitely need one on the front. What would the car handle like with no sway bars? What thickness bar on the front?
JD
Old 11-01-2013, 05:51 AM
Aussie Mike's Avatar
I ran mine with no bars an had a lot of understeer on the track.
Mike Murphy
Melbourne Australia
Old 11-02-2013, 02:25 PM
Baz's Avatar
Baz Baz is offline
Sure wasn't understeer Gav.........Not from where I was standing at any rate. As Towy says, 'The back definately passed the front' in a big way.
