Like Tree11Likes
Old 12-01-2013, 06:17 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
i think it's got some reasonable go fast gear on it, ie heads manifold and ignition is mallory, cam seems ok, its pulling 300rwhp on the dyno, but not for long with the current fuel pump problem but has been suggested by the dyno bloke it will pull over 350rwhp with the 670 avenger good tune and fuel pump, exhaust and cam would be next if i wanted anymore.
Old 12-01-2013, 06:27 PM
Towmaster's Avatar
Realistically, if you are getting 300 rwhp from a 302 it's a pretty good 302.... Unless it's a 'happy' dyno. You won't get much more unless you spend a lot of money to get it to rev. Alternatively you could opt to stroke it to 347 cubes. That will give you a fair bit more power and torque.
Old 12-01-2013, 06:36 PM
the dyno bloke said he was pretty suprised it pulled that sort of figure, he reved it to 6500 rpm but it was at its best at 5900rpm, but the fuel ratios where good until the secondaries kept running out of fuel.
