Like Tree6Likes
Old 12-26-2013, 09:46 PM
renovationinnov's Avatar
Thumbs up up & running
today at 2pm ,,I had live in the ls1 first time start up
found 2 fuel leaks in the tank , 1 coolant leak in the bottom of the radiator but have got 20 plus kpa oil pressure at idle [ fast \]
I have a question some may help
it started up after priming but idled like nothing I have seen before ]it revved then settled then revved then settled for the first minute then I shut it down
after checking out everything I restarted it it did the same thing over &over again then settled after going thru the gear in the auto but I now don't have park
I can put it in park while running & still move [ push it back & forwards ]so any ideas would be helpful
rob
it,s alive
Old 12-26-2013, 10:17 PM
Gav's Avatar
Gav Gav is offline
The idle air motor will modulate up and down trying to sort out the idle.
It should start briefly rev to maybe 12-1400rpm and then settle down.
Back to the auto, remove the linkage and rotate the input shaft to park.
See if maybe the linkage was not adjusted correctly?
boxhead likes this.
Powered by Cu
Old 12-26-2013, 11:15 PM
Zedn's Avatar
Look do air leaks in the intake. Sound like it is struggling to correct the mixture and chasing its tail. Also check maf, map and o2 sensors. A scan for codes would also help.
Congrats on the milestone. I fired mine up for the first time on Christmas Eve. Very exciting moment!
Old 12-27-2013, 12:51 AM
I think I found my first problem ,,,,no air temp sensor
GAV tried the rotation of the shaft but to no avail was in the correct stop
might call an auto specialist & ask a few questions
find out why the tacho is not working as well [ it might be a job for jim ] sideshow when he gets back off holidays
Old 12-27-2013, 03:25 AM
750hp's Avatar
Congrats on getting it running Rob!
Craig
Old 12-27-2013, 04:55 AM
Mando's Avatar
Congratulations, big step!
Regards.
Mando
Old 12-27-2013, 04:57 AM
Mando's Avatar
Regards.
Mando
Old 12-27-2013, 05:55 AM
Gav's Avatar
Gav Gav is offline
Have you connected the pink pos wire for the trans?
Powered by Cu
Old 12-27-2013, 01:30 PM
park is a mechanical gear so it should not need electronics
park is when lever on gbox is all the way back
plus u can always tell park position as all other gear positions are small clicks and when u click into park it is a longer click
and if u had it back to front it would be in 1st when lever is in park and when u rev it it would try to drive forward
sounds like parking pawl lever aint engaging
my website
www.sideshowsperformancewiring.com.au
Old 12-27-2013, 03:36 PM
ok ''im an idot
I was thinking as a normal person ' not a car from mr ,,tucker
he has cut down the lever on the side of the box & when I thought [ again] it was in park ,the lever was hitting the electronics for the gear box so now of to the wreckers to find the right lenth arm [ shift lever ] you got to love mr .*#@*tucker
I have moved the arm & have park thanks guy again
Old 12-27-2013, 09:27 PM
Gav's Avatar
Gav Gav is offline
An aftermarket shifter will have the appropriate length operator arm included with it.
Powered by Cu
Old 12-27-2013, 10:54 PM
just remember the holdens have two lots of D's on the shifter
so u need a std comm shifter or one with a 4 gate system not a 3 gate system
b&m shifters have a pin which u remove to switch from 3 to 4 gate
my website
Old 12-28-2013, 07:26 PM
now for the next problem to solve
I bought a lokar shifter & electrics so to solve all problems
no wrong again
I fitted it as per instructions but to my misfortune the park seams to move each time I adjust it
so under the car I go with spanner in hand to tighten the linkage & find that the box shift shaft will rotate to any position which but where it is meant to be
so park can be vertical or horizional at any time after you run it thru tis gears selection
any thoughts as to WHY!!!!
ROB
Old 12-28-2013, 09:23 PM
Gav's Avatar
Gav Gav is offline
I reckon your box is shagged
Powered by Cu
Old 12-29-2013, 01:50 AM
well its back to the auto services to get them to re check & fix it as they should under warranty
there check & pre fitment was said no over haul need ,,only major service
so another set back to over come
Old 12-29-2013, 01:59 AM
u cant trust auto trans shops heheeh
I had a spit at one of them
bloody charged a customer 700 bucks to check auto and do up converter
the stupid dickhead didn't know much about Toyota gboxes and tested it with no
electronics so I told him in a very loud voice how these gboxes work and with no
electronics how the hell could he have checked the box hehehehe
its not the repairing of the box that's the issue
its the fact a shop has to remove it and refit it again at customers expense
I swear there is fk all good automotive trades people around these days
my website
Old 12-29-2013, 03:16 AM
Gaz64's Avatar
Ha Ha, see it all the time. I shake my head at incompetence every day.
Old 12-29-2013, 12:43 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
I had my auto seviced in a 5 litre fairlane years ago, i said to the bloke did you change fluids and filters? to which he replied yes, i then asked him how did you do it with out taking the pan off? i did he said,
i said, well why is there a piece of cow **** that runs over the pan, old gasket and gearbox?
he finally admitted he had just sucked the fluid out and hadnt changed the filters.
Old 12-29-2013, 04:00 PM
itempany's Avatar
Cobra Make, Engine: Drb, 302 Comp cam, Cobra Nationals 2001 and 2002
And the further north you go.....the servicing gets worse.
Old 12-29-2013, 04:19 PM
well I rang this guy about the problem & guess what he said
that it was my fault for touching it
to adjust it & fix the problem he needs to pull the box at my cost , then solve the problem at my cost
as he only serviced & checked internals for damage or wear
iii asked so what did he move it thru the range of selection by the shifter
here is the best ...............it electronic & it shifts electronically & park is electronically activated by the shifter so there is no linkages
then I told him so why does mine have a selector shaft & linkages off the side of it
he hung up on me
so I rang back & was told
that I had touched it & now had no warranty
I said consumer affairs have a different point a view on that ...... he hung up again
assh.......o.....l....e
any one recommend a good auto repairer north side Redcliffe way
