Old 01-16-2014, 01:04 AM
Default Header paint
Just wondering if anyone has had experience with a halfway decent header paint? Have used VHT header paint on an old car of mine before, but found that the colour burned off in about a week. Not a problem if you want black headers I guess, but I was hoping for a silver/grey
Don't want to have them coated, as they are a 'just till I can run sidepipes' set.
Any thoughts welcomed TY
Old 01-16-2014, 01:27 AM
Zedn's Avatar
I built my headers so they will work with both side pipes and under car exhaust. Then had them coated nice and shiny.
I heard the vht was ok if you use the right one. The thing I didn't like was it is only matt. There is a guy at Penrith who does ceramic coating on small scale with reasonable prices. I spoke to him about mine but he couldn't do chrome look. He can do metallic silver and was a really nice helpful guy. Worth a call as it might only be an extra 100 over what you will pay for paint cans.
Craved Coatings - Custom Powder Coating and Exhaust Ceramic Coatings
Old 01-16-2014, 02:54 AM
sambo's Avatar
I heard the trick was to cure the VHT paint slowly onto the headers in your kitchen oven. May be hazardous to your marriage though.
Old 01-16-2014, 03:36 AM
The oven, you say... hmm
So if I tell the missus i'm making a special dinner and she should stay out the kitchen for a few hours, I should get away with the horrible smell
Old 01-16-2014, 04:01 AM
jcraigau's Avatar
I used silver VHT from Bunnings and it's still going strong 2 years later.
The only problem was when the Karcher got a little close and stripped off about an inch wide section. Needed to mask it off and re-apply. Now just need to be careful when doing any under-bonnet cleaning!
Old 01-16-2014, 03:04 PM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Karcher under the bonnet, thats a bit scary, been doing some 4wding!
Old 01-16-2014, 03:55 PM
joyridin''s Avatar
I had a set of headers powder coated in high temp powder some years ago. It was pretty cheap compared to ceramic or any type of coating like that. Held up great! Had exhaust manifolds done the same way. No problems.
Old 01-16-2014, 04:36 PM
Gav's Avatar
Gav Gav is offline
How does high temp powder coat work?
If it holds up to exhaust temps then it must require near the temperature of the surface of the sun to be baked on!!
Sure it wasn't spray metal or something like that?
Powered by Cu
Old 01-16-2014, 05:03 PM
jcraigau's Avatar
I slow leaking power steering pump that gunked up the front of the block. Seemed the easiest way to clean it all off...
Old 01-16-2014, 05:39 PM
joyridin''s Avatar
Not sure, but it was powder coat. You can buy it from Eastwood.
Old 01-16-2014, 05:54 PM
Wazza's Avatar
It's good stuff..
I've had the headers done on the Windsors, and also the LS7.
High Performance Coatings | HP1 - Exhaust System Coatings
Warren
Old 01-17-2014, 07:37 AM
Bryan Wilson's Avatar
Default Header coating
My headers were originally Jet Hot coated but it burnt off so I painted them with VHT paint silver. they look like flat aluminium and have never discoloured or burnt off.
Bryan
VK3KDN
Old 01-19-2014, 08:12 PM
Trickycoupe's Avatar
After having my pipes ceramic coated a few times previously at great expense, I decided to use high temp paint.
I used KBS Coating Extreme exhaust paint on my GT40 headers. Even after full noise runs (on a race track) it hasn't moved or discoloured.
I blasted the pipes before brush painting the coating on and I think they came out great for a $60.00 investment.
KBS High Temperature Paint
Ricky
RF GT40, Ralt RT5
