November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-18-2014, 02:01 AM
Cobra Make, Engine: DRB, 302 EFI 5 speed 9"
Default Surging problem
Hi everyone,
I am running a AU XR8 engine that has started a surging type of problem whilst cruising at around 60kms/hr and has a slight flat spot just on the throttle from idle position.
If I slow down, go around a intersection then put the foot down to accelerate away there is the flat spot then surging before it accelerates.
The motor is bog stock and hasn't always done.
I fitted a low pressure fuel filter before the pump, replaced the pump and high pressure filter with little change.
Any suggestions on what it could be or if it could even be electrical.
Cheers Ross
Old 02-18-2014, 02:32 AM
dhs.buckley's Avatar
Cobra Make, Engine: Python ford 302 ho, 4 speed toploader, jag irs 3.54
Could be clagged up oxy sensors or maybe your throttle body air sensor is dirty, also voltage drops to the sensors can cause this problem.
Old 02-18-2014, 03:09 AM
renovationinnov's Avatar
Cobra Make, Engine: venom motorsports /ls1 auto
I had that problem at first & found a leak in vacuum line at the rear of mine right beside the vac sensor
rob
not all your babies are your children
Old 02-18-2014, 11:17 PM
Zedn's Avatar
Has it got an airflow meter? That would be my guess or O2 sensors. Scan for codes or try disconnecting the sensors to see if they make a difference.
Old 03-17-2014, 06:29 AM
After checking everything I could it turned out to be the speed sensor in the gearbox.
