Like Tree1Likes
  • 1 Post By joyridin'
Old 02-19-2014, 02:11 AM
750hp's Avatar
Default IM240 and E85
If an engine is at risk of not meeting IM240 emissions, is an E85 tune an option? For all of the talk about clean burning ethanol, is this something that has been explored? I haven't seen any solid back-to-back tests on a performance engine to know if this is a solution.
Craig
Old 02-20-2014, 01:37 PM
d488y2's Avatar
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
I’ve read various reports on the web that E85 improves emissions.
Old 02-20-2014, 02:43 PM
joyridin''s Avatar
I am not sure about emissions, but if you are going to go through the hassle of changing to E85, you might as well modify the engine to take advantage of the performance potential. On the LS1 site I frequent, guys are running 12.5:1 compression with 10 or more pounds of boost and getting 1000 hp. Hitting 700-800 hp on E85 is pretty common. The one guy has 11:1 compression with 20 pounds of boost and over 1100 hp.
By the time you factor in the octane and the cooling effect of the alcohol, it is around 115 octane.
Rob. Smith likes this.
Rate This Thread:
